Hi, I am trying to modify a global int using set_action from a template number:
globals:
- id: setpoint1
type: int
restore_value: no
initial_value: '25'
number:
name: "Setpoint accensione camino da HA"
optimistic: true
unit_of_measurement: °C
min_value: 20
max_value: 70
initial_value: 25
step: 1
set_action:
then:
- lambda: id(setpoint1) = id(setpoint1_ha);
the global int is used in a kind of thermostat:
- platform: dallas
address: 0xb2838a4b1f64ff28
on_value:
then:
- script.execute: avvio_camino
script:
- id: avvio_camino
then:
- lambda: |-
if (id(camino).state > id(setpoint1)) {
id(switch1).turn_on();
} else if (id(camino).state < (id(setpoint1) - id(isteresi1))) {
id(switch1).turn_off();
but i got the error message in lambda action when compiling:
/config/esphome/termocamino.yaml: In lambda function:
/config/esphome/termocamino.yaml:55:26: error: invalid conversion from 'esphome::template_::TemplateNumber*' to 'int' [-fpermissive]
*** [/data/termocamino/.pioenvs/termocamino/src/main.cpp.o] Error 1
========================= [FAILED] Took 12.52 seconds =========================
I ahe tried to define the global as FLOAT, got a similar error
/config/esphome/termocamino.yaml:55:26: error: cannot convert 'esphome::template_::TemplateNumber*' to 'float' in assignment
what can I do?
