I have a 4 channels led aquarium light that is controlled by an IR control. With the remote I can control the intensity of every channel, because every channel have one color, to simulate sunlight at dawn, noon, evening, etc…what I want to do is use a broadlink rm3 IR remote that I integrated with HA and use to power on and off other devices, to control this light. I learned the light remote control , tried, and all works fine.
So, what I really need is write a blueprint to automate the intensity of every channel at different day hours. With my little acknowledgment writing blueprints and the gemini help,. I wrote it, but have two problems… I can choose the broadlink rm3 as IR emitter, but can’t choose the device that is controlled. I am loosing something in the code for this. And in the automation, after load the bIueprint, I can add the time to trigger the remote.send_command action, but I have no idea how to add the % of power for every channel in the list created… Maybe I am focusing the automation in a wrong way, and there is better options than a blueprint. I know I can do it with several automations, creating one for every light and for every channel intensity change, but this will be a lot of automations to create and would consume a lot of resources. I even thought to do it with an esp32 with IR led with esphome, but I have the broadlink that already control IR devices… this is the code
blueprint:
name: Control de luces de acuario marino
description: Controla las luces de un acuario marino según un horario y porcentajes de intensidad.
domain: automation
input:
dispositivo_ir:
description: Selecciona el dispositivo que controlarás.
selector:
device:
horarios:
description: Lista de horarios y porcentajes de intensidad.
selector:
object:
mode: single
- platform: time
at: "{{ repeat.item.horario }}"
- variables:
estados_deseados: "{{ repeat.item.estados }}"
estados_actuales: "{{ states('sensor.estados_actuales_luces') | from_json | default({}) }}"
porcentajes: [0, 2, 5, 10, 20, 30, 40, 50, 60, 70, 80, 90, 100]
- repeat:
for_each: "{{ horarios }}"
sequence:
- repeat:
until:
- condition: template
value_template: "{{ estados_actuales == estados_deseados }}"
sequence:
- choose:
- conditions: "{{ estados_actuales.canal1 < estados_deseados.canal1 }}"
sequence:
- service: remote.send_command
device_id: "{{ dispositivo_ir }}"
command: Canal1+
device: rm3
- conditions: "{{ estados_actuales.canal1 > estados_deseados.canal1 }}"
sequence:
command: Canal1-
device: rm3
- conditions: "{{ estados_actuales.canal2 < estados_deseados.canal2 }}"
sequence:
command: Canal2+
device: rm3
- conditions: "{{ estados_actuales.canal2 > estados_deseados.canal2 }}"
sequence:
command: Canal2-
device: rm3
- conditions: "{{ estados_actuales.canal3 < estados_deseados.canal3 }}"
sequence:
command: Canal3+
device: rm3
- conditions: "{{ estados_actuales.canal3 > estados_deseados.canal3 }}"
sequence:
command: Canal3-
device: rm3
- conditions: "{{ estados_actuales.canal4 < estados_deseados.canal4 }}"
sequence:
command: Canal4+
device: rm3
- conditions: "{{ estados_actuales.canal4 > estados_deseados.canal4 }}"
sequence:
command: Canal4-
device: rm3
- variables:
nuevos_estados: >
{% set nuevos_estados = estados_actuales.copy() %}
{% if estados_actuales.canal1 < estados_deseados.canal1 %}
{% set nuevos_estados = nuevos_estados | combine({'canal1': [estados_actuales.canal1 + 1, estados_deseados.canal1] | min}) %}
{% elif estados_actuales.canal1 > estados_deseados.canal1 %}
{% set nuevos_estados = nuevos_estados | combine({'canal1': [estados_actuales.canal1 - 1, estados_deseados.canal1] | max}) %}
{% elif estados_actuales.canal2 < estados_deseados.canal2 %}
{% set nuevos_estados = nuevos_estados | combine({'canal2': [estados_actuales.canal2 + 1, estados_deseados.canal2] | min}) %}
{% elif estados_actuales.canal2 > estados_deseados.canal2 %}
{% set nuevos_estados = nuevos_estados | combine({'canal2': [estados_actuales.canal2 - 1, estados_deseados.canal2] | max}) %}
{% elif estados_actuales.canal3 < estados_deseados.canal3 %}
{% set nuevos_estados = nuevos_estados | combine({'canal3': [estados_actuales.canal3 + 1, estados_deseados.canal3] | min}) %}
{% elif estados_actuales.canal3 > estados_deseados.canal3 %}
{% set nuevos_estados = nuevos_estados | combine({'canal3': [estados_actuales.canal3 - 1, estados_deseados.canal3] | max}) %}
{% elif estados_actuales.canal4 < estados_deseados.canal4 %}
{% set nuevos_estados = nuevos_estados | combine({'canal4': [estados_actuales.canal4 + 1, estados_deseados.canal4] | min}) %}
{% elif estados_actuales.canal4 > estados_deseados.canal4 %}
{% set nuevos_estados = nuevos_estados | combine({'canal4': [estados_actuales.canal4 - 1, estados_deseados.canal4] | max}) %}
{% endif %}
{{ nuevos_estados }}
- service: sensor.update_entity
entity_id: sensor.estados_actuales_luces
state: "{{ nuevos_estados | to_json }}"
