Problem in automation: value_template: comparisson don´t work
Hey there,
i´am trying my first automation in HA.
A fan should be controlled depending on the absolute humidity.
I would like to compare two sensor values, but this does not work.
Anyone know what I did wrong?
Here is the complete code.
(I used the Automation Editor.)
alias: Ventilator_Auto
description: Steuerung Garagenventilator
  - platform: state
    entity_id:
      - sensor.absolute_luftfeuchte_aussen
      - sensor.absolute_luftfeuchte_garage
      - input_number.garageventilatorabsfeuchteschwellwert
      - timer.garageventilatorlaufzeitintervall
      - timer.garageventilatorpausenintervall
      - switch.ventilator
condition: []
  - if:
      - condition: state
        state: "on"
        entity_id: input_boolean.garageventilatordauerluften
    then:
      - type: turn_on
        device_id: 163377eb8ab786af0d7fdde5097a026f
        entity_id: switch.ventilator
        domain: switch
      - service: timer.cancel
        data: {}
          entity_id:
    else:
      - if:
          - condition: template
            value_template: >-
              "{{states('sensor.absolute_luftfeuchte_aussen')| float >
              states('sensor.absolute_luftfeuchte_garage')| float}}"
          - condition: state
            state: "off"
        then:
          - type: turn_off
            domain: switch
            data: {}
              entity_id:
        else:
          - if:
                value_template: >-
                  "{{ states('sensor.absolute_luftfeuchte_aussen') | float <=
                  (states('sensor.absolute_luftfeuchte_garage') | float +
                  states('input_number.garageventilatorabsfeuchteschwellwert') |
                  float) }}"
              - condition: state
                entity_id: timer.garageventilatorlaufzeitintervall
                state: idle
              - condition: state
                entity_id: timer.garageventilatorpausenintervall
                state: idle
            then:
              - type: turn_on
                domain: switch
              - service: timer.start
                data: {}
              - type: turn_off
                domain: switch
                data: {}
            else:
              - if:
                  - condition: state
                    state: idle
                  - condition: state
                    state: idle
                then:
                  - type: turn_off
                    domain: switch
mode: single
The problematic areas are:
      - if:
            value_template: >-
and
          - if:
                value_template: >-
                  float) }}"
You need to assign defaults for your float filters…
      - if:
          value_template: >-
            {{ states('sensor.absolute_luftfeuchte_aussen')| float(0) >
            states('sensor.absolute_luftfeuchte_garage')| float(0) }}
      - if:
          value_template: >
            {{ states('sensor.absolute_luftfeuchte_aussen') | float(0)
            <= states('sensor.absolute_luftfeuchte_garage') | float(0) +
            states('input_number.garageventilatorabsfeuchteschwellwert') | float(0) }}
Thanks, the problem is solved. The main reason, however, was the quotation marks.
But I still have another problem:
then:
              - type: turn_on
                domain: switch
                data: {}
              - condition: state
                entity_id: input_boolean.luftungspause_erledigt
                state: "on"
In the last entry, I don’t want to query the status. I want to set it to a new value.
The entity is boolean - a helper switch that can be on or off.
But I don’t know the syntax to set the value…
If I understand what you are asking correctly, you need to call the input_boolean.turn_on service.
then:
  - type: turn_on
    domain: switch
    data: {}
You´re right and my automation works. Thanks!!
