Problem in UI editor
I have come across an issue in the visual UI editor, if you drag and drop an action into an other action it deletes it. But not every time.
As an example:
I have two choose building blocks, created a run in sequence action, drag both choose actions, it deletes the second one. The first time it happened I did not catch it and saved the automation losing the data.
Nice to have back ups!
Have you tried a different browser from the one (which one?) you are using?
This sounds familiar…
There may be an issue open for this, and if not, you should write one. This post won’t be seen by the people that could fix it.
Frontend Issues .
