Hello
I am having a problem connecting to the local Dashboard on python (windows 11)
So I installed Python and Esphome (Version: 2023.11.6) without any problem on Windows 11 by following the Pyc tech tutorial [https://www.youtube.com/watch?v=9xy8D8B1sTw 1]
It gets stuck when I configure the dashboard with the command “esphome dashboard configuration”
on the video it’s at 3:24
For my part I have several error lines on python and if I enter my IP address with port 6052 I have a connection refused
there are many other parameters to enter but in the video only “esphome dashboard configuration” is enough!!!
An idea ?
thanks in advance
C:\Users\domin>esphome version
> Version: 2023.11.6
> C:\Users\domin>esphome dashboard
> usage: esphome dashboard [-h] [--port PORT] [--address ADDRESS] [--username USERNAME] [--password PASSWORD]
> [--open-ui] [--socket SOCKET]
> configuration
> esphome dashboard: error: the following arguments are required: configuration
> C:\Users\domin>esphome dashboard configuration
> 2023-12-13 00:47:23,970 INFO Starting dashboard web server on http://0.0.0.0:6052 and configuration dir configuration...Traceback (most recent call last):
> File "<frozen runpy>", line 198, in _run_module_as_main
> File "<frozen runpy>", line 88, in _run_code
> File "C:\Users\domin\AppData\Local\Programs\Python\Python312\Scripts\esphome.exe\__main__.py", line 7, in <module>
> File "C:\Users\domin\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\__main__.py", line 1040, in main
> return run_esphome(sys.argv)
> File "C:\Users\domin\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\__main__.py", line 1003, in run_esphome
> return PRE_CONFIG_ACTIONS[args.command](args)
> File "C:\Users\domin\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\__main__.py", line 517, in command_dashboard
> return dashboard.start_web_server(args)
> File "C:\Users\domin\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\dashboard\dashboard.py", line 1517, in start_web_server
> status_thread = MDNSStatusThread()
> File "C:\Users\domin\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\dashboard\dashboard.py", line 977, in __init__
> self._refresh_hosts()
> File "C:\Users\domin\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\dashboard\dashboard.py", line 981, in _refresh_hosts
> entries = _list_dashboard_entries()
> File "C:\Users\domin\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\dashboard\dashboard.py", line 726, in _list_dashboard_entries
> return settings.entries()
> File "C:\Users\domin\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\dashboard\dashboard.py", line 148, in entries
> for file in self.list_yaml_files():
> File "C:\Users\domin\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\dashboard\dashboard.py", line 129, in list_yaml_files
> return util.list_yaml_files([self.config_dir])
> File "C:\Users\domin\AppData\Local\Programs\Python\Python312\Lib\site-packages\esphome\util.py", line 292, in list_yaml_files
> [os.path.join(folder, p) for folder in folders for p in os.listdir(folder)]
> FileNotFoundError: [WinError 3] Le chemin d’accès spécifié est introuvable: 'configuration
