Hello everyone. The following problem has arisen. When installing the config I received the following message
INFO ESPHome 2024.12.4
INFO Reading configuration /config/esphome/doorbell.yaml…
Failed config
esphome: None
expected a dictionary.
Hi
This forum is only in english so please update your post in english and post also your yaml here instead of a link to google drive
Vincèn
Could you post your doorbell.yaml?
Remember to redact OTA pass, API key, WiFI pass and so on, if you are not using the secret file.
And if you can then update the headline to English too. It will bring more people to your post.
I am a newbie, where can I upload the configuration file for viewing?
You should have an ESPHome Builder option in your left side menu.
Select it and you should see the nodes you have configured now.
One should be you doorbell.yaml and when clicking edit you can see the text.
Copy the text and insert it here. Remember to redact your private information.
