I had an old HACS version I removed, and then tried installing the Integration. This results in the following error:
Config flow could not be loaded: 500 Internal Server Error Server got itself in trouble
I can’t find any leftover folders or the like. Any ideas?
Logs:
Logger: aiohttp.server
Source: /usr/local/lib/python3.14/site-packages/aiohttp/web_protocol.py:488
First occurred: 06:54:49 (8 occurrences)
Last logged: 08:35:42
Error handling request from 192.168.0.153
File "/usr/local/lib/python3.14/site-packages/aiohttp/web_protocol.py", line 517, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.14/site-packages/aiohttp/web_app.py", line 569, in _handle
return await handler(request)
File "/usr/local/lib/python3.14/site-packages/aiohttp/web_middlewares.py", line 117, in impl
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 87, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 90, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 295, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 41, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 89, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 83, in with_admin
return await func(self, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
return await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 188, in post
return await self._post_impl(request, data)
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 195, in _post_impl
return await super()._post_impl(request, data)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 83, in _post_impl
result = await self._flow_mgr.async_init(
...<2 lines>...
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1493, in async_init
flow, result = await self._async_init(flow_id, handler, context, data)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1546, in _async_init
flow = await self.async_create_flow(handler, context=context, data=data)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1768, in async_create_flow
handler = await _async_get_flow_handler(
self.hass, handler_key, self._hass_config
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 4060, in _async_get_flow_handler
await _load_integration(hass, domain, hass_config)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 4037, in _load_integration
await async_process_deps_reqs(hass, hass_config, integration)
File "/usr/src/homeassistant/homeassistant/setup.py", line 584, in async_process_deps_reqs
await requirements.async_get_integration_with_requirements(
hass, integration.domain
File "/usr/src/homeassistant/homeassistant/requirements.py", line 61, in async_get_integration_with_requirements
return await manager.async_get_integration_with_requirements(domain)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 179, in async_get_integration_with_requirements
await future
File "/usr/src/homeassistant/homeassistant/requirements.py", line 168, in async_get_integration_with_requirements
await self._async_process_integration(integration, done)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 191, in _async_process_integration
await self.async_process_requirements(
integration.domain, integration.requirements, integration.is_built_in
File "/usr/src/homeassistant/homeassistant/requirements.py", line 303, in async_process_requirements
self._raise_for_failed_requirements(name, missing)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 331, in _raise_for_failed_requirements
raise RequirementsNotFound(integration, [req])
homeassistant.requirements.RequirementsNotFound: Requirements for unifiprotect not found: ['pyunifiprotect==3.1.1'].
