Problem records only 12 hours
Hello, can someone tell me why this automation only records from 10:00 to 22:00?
alias: Grabacion timbre
description: ''
triggers:
  - type: motion
    device_id: bb19d544320ae3ffbc8419a4f9e43eca
    entity_id: eae134f1b723453c1c2424b0febfd1914
    domain: binary_sensor
    trigger: device
    enabled: true
  - trigger: state
    entity_id:
      - binary_sensor.puerta_principal_motion
    attribute: personDetected
    enabled: false
conditions: []
actions:
  - action: camera.record
      entity_id: camera.172_23_0_2
      filename: >-
        /media/Grabaciones/HA/Entrada_{{ now().strftime('%Y-%m-%d_%H-%M-%S')
        }}.mp4
      duration: 30
mode: queued
max: 10
type or paste code here
Hello Phrana,
Are both triggers for the same sensor? Do you know which are triggering.
So a couple of thoughts, if the device trigger and state trigger are for the same sensor, dump the device trigger.
Is there any other software involved. I suspect something like an app that set the detection enable to only work certain times of day. like 10am to 10pm…
You can see in the image that there is only one trigger, in the mobile app, all detections appear
I can’t see the text in the image. Screenshots are not my friend.
How to help us help you - or How to ask a good question.
The code that is in the first post is the same as in automations.yaml and there are no more triggers
I have tried differently but nothingi
description: ''
triggers:
  - type: motion
    trigger: device
    enabled: true
  - trigger: state
    entity_id:
    enabled: false
conditions: []
actions:
      filename: >-
    /media/Grabaciones/HA/Entrada_{{ now().timestamp() |
    timestamp_custom('%Y-%m-%d_%H-%M-%S') }}.mp4
  duration: 30
mode: queued
max: 10
I would suggest you to post screenshots in English.
Screenshots should be understandable by community members.
The question was - “what is a point to have 2 triggers instead of one”?
(another issue is about using a device-id-based trigger instead of a normal, reliable and maintainable entity-id-based one - link).
