Hi all,
I have sensor.mqttgarage that is a string with the value of many sensor:
- platform: mqtt
state_topic: "home-assistant/sensor03/messaggio"
qos: 0
Now, I need to create many single sensor, like this:
sensors:
frequency:
value_template: "{{ states('sensor.mqttgarage').split(',')[8] | float }}"
unit_of_measurement: "Hz"
But HA doesn’t show the sensor.frequency…
Where is the error?
petro
(Petro)
October 22, 2021, 10:56am
2
indicies start at 0, not 1. So your first item is 0 and your last item is 7. You’re using 8. That’s why it’s failing. Also, you don’t need the word float, that will only hurt you in this case.
value_template: "{{ states('sensor.mqttgarage').split(',')[7] }}"
thanks for you reply…
I know, I have 9 sensors, so from 0 to 8…
I tried also without float but the same problem…
petro
(Petro)
October 22, 2021, 11:00am
4
Also, as a sidebar, you can make template sensors without the mqttgarage sensor:
template:
- trigger:
- platform: mqtt
topic: home-assistant/sensor03/messaggio
- name: First item
state: "{{ value.split(',')[0] }}"
- name: Second item
state: "{{ value.split(',')[1] }}"
... ETC...
- name: Frequency (Last Item)
state: "{{ value.split(',')[-1] }}"
petro
(Petro)
October 22, 2021, 11:01am
5
Then your topic is wrong or you didn’t reload templates after adding the template. Or if you’re using the new template integration, you didn’t restart home assistant.
I tried this, but sensor.frequency is unavailable
template:
- trigger:
- platform: mqtt
- name: frequency
state: "{{ value.split(',')[8] }}"
petro
(Petro)
October 22, 2021, 12:20pm
7
oops, it should be
template:
- trigger:
- platform: mqtt
- name: frequency
state: "{{ trigger.payload.split(',')[8] }}"
petro:
trigger.payload.
many thanks, if I need to scale the value, for example /1000?ù
like this doesn’t work:
state: “{{ ( trigger.payload.split(‘,’)[1] / 1000 ) | float | round (1) }}”
petro
(Petro)
October 22, 2021, 12:45pm
9
float has to be applied before you divide
