Problem setting up Bosch Smart Home
Hello, I’m new to the Home Assistant community and am currently setting up my devices. I have the following problem:
I’ve set up my Bosch Smart Home Controller, and HA has detected six devices, including the controller. However, the smartphone app shows eight devices. I have a dimmer switch, two radiator thermostats, two door contacts, a universal switch, and a room thermostat.
The dimmer switch and the room thermostat are not displayed in HA.
The room thermostat is paired with a radiator thermostat and is not detected by HA. Is this normal? If not, how can I fix the problem?
Thank you in advance!
Hi Torsten, welcome to the forum!
Where (which screen) are you looking at those devices?
Have a look at the entities and check if you can see them there:
Open your Home Assistant instance and show your entities.
Have you seen this: Bosch SHC - Home Assistant
Your thermostat should be available as a sensor but no signs of a dimmer…
Hello @Nick4,
Thanks for the report. I’ve now solved the problem with the “Bosch Smart Home” program from tschamm.
Best regards, Torsten
Good you got it solved!
Please take the time to mark the solution as the answer, you do that by selecting the three dots under the post:
Then select the check box:
By doing so:
  • this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
  • this prevents that someone else steps in trying to help
Thanks for giving back to the community! :+1:
