I’m fairly new to Home Assistant (and just created an account in the Home Assistant Community) so forgive me if I say anything “stupid”–I’m learning.
I’m having trouble getting the Mosquitto Broker to work on my set up. Here is a brief of the problem:
My setup:
-I have home assistant 0.113.3 running in a docker container on a NUC running Ubuntu 20.04
-I have a HUSBZB-1 USB hub for Zigbee and Zwave - both of which are working great (have lights, etc. devices working)
I recently bought an Xiaomi Aqara Temperature and Humidity Sensor (w/ barometric pressure) model WSDCGQ11LM and tried to get it integrated into home assistant. It is my understanding to pick this up I need to be able to receive Zibbee2mqtt. To do this I tried to follow the published MQTT instructions (IE install Mosquitto Broker and then add the MQTT integration with device discovery).
I’ve been attempting to install this several times. My first installation of Mosquitto Broker seemed to work; it automatically found the MQTT device; however i couldn’t’ get the device discovery to work (either that or I forgot to do something). I uninstalled the Mosquitto Broker and then tried reinstalling again. After doing that, I’m getting errors in the log. See below. Any idea what I’m doing wrong?
When I go into add the MQTT integration it doesn’t show up automatically, and when I try to add it manually I get an “Unable to Connect to the Broker” error. I guess I’m not totally sure what the “broker” name is supposed to be. Maybe I’m entering that wrong? Or maybe it’s the error below with Mosquitto Broker that is causing the problem?
Any help would be much appreciated!!
MOSQUITTO BROKER LOG:
1596353232: Error: No such file or directory.
1596355033: Saving in-memory database to /data/mosquitto.db.
1596355033: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596355033: Error: No such file or directory.
1596356834: Saving in-memory database to /data/mosquitto.db.
1596356834: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596356834: Error: No such file or directory.
1596358635: Saving in-memory database to /data/mosquitto.db.
1596358635: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596358635: Error: No such file or directory.
1596360436: Saving in-memory database to /data/mosquitto.db.
1596360436: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596360436: Error: No such file or directory.
1596362237: Saving in-memory database to /data/mosquitto.db.
1596362237: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596362237: Error: No such file or directory.
1596364038: Saving in-memory database to /data/mosquitto.db.
1596364038: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596364038: Error: No such file or directory.
1596365839: Saving in-memory database to /data/mosquitto.db.
1596365839: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596365839: Error: No such file or directory.
1596367640: Saving in-memory database to /data/mosquitto.db.
1596367640: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596367640: Error: No such file or directory.
1596369441: Saving in-memory database to /data/mosquitto.db.
1596369441: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596369441: Error: No such file or directory.
1596371242: Saving in-memory database to /data/mosquitto.db.
1596371242: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596371242: Error: No such file or directory.
1596373043: Saving in-memory database to /data/mosquitto.db.
1596373043: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596373043: Error: No such file or directory.
1596374844: Saving in-memory database to /data/mosquitto.db.
1596374844: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596374844: Error: No such file or directory.
1596376645: Saving in-memory database to /data/mosquitto.db.
1596376645: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596376645: Error: No such file or directory.
1596378446: Saving in-memory database to /data/mosquitto.db.
1596378446: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596378446: Error: No such file or directory.
1596380247: Saving in-memory database to /data/mosquitto.db.
1596380247: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596380247: Error: No such file or directory.
1596382048: Saving in-memory database to /data/mosquitto.db.
1596382048: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596382048: Error: No such file or directory.
1596383849: Saving in-memory database to /data/mosquitto.db.
1596383849: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596383849: Error: No such file or directory.
1596385650: Saving in-memory database to /data/mosquitto.db.
1596385650: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596385650: Error: No such file or directory.
1596387451: Saving in-memory database to /data/mosquitto.db.
1596387451: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596387451: Error: No such file or directory.
1596389252: Saving in-memory database to /data/mosquitto.db.
1596389252: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596389252: Error: No such file or directory.
1596391053: Saving in-memory database to /data/mosquitto.db.
1596391053: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596391053: Error: No such file or directory.
1596392854: Saving in-memory database to /data/mosquitto.db.
1596392854: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596392854: Error: No such file or directory.
1596394655: Saving in-memory database to /data/mosquitto.db.
1596394655: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596394655: Error: No such file or directory.
1596396456: Saving in-memory database to /data/mosquitto.db.
1596396456: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596396456: Error: No such file or directory.
1596398257: Saving in-memory database to /data/mosquitto.db.
1596398257: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596398257: Error: No such file or directory.
1596400058: Saving in-memory database to /data/mosquitto.db.
1596400058: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596400058: Error: No such file or directory.
1596401859: Saving in-memory database to /data/mosquitto.db.
1596401859: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596401859: Error: No such file or directory.
1596403660: Saving in-memory database to /data/mosquitto.db.
1596403660: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596403660: Error: No such file or directory.
1596405461: Saving in-memory database to /data/mosquitto.db.
1596405461: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596405461: Error: No such file or directory.
1596407262: Saving in-memory database to /data/mosquitto.db.
1596407262: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596407262: Error: No such file or directory.
1596409063: Saving in-memory database to /data/mosquitto.db.
1596409063: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596409063: Error: No such file or directory.
1596410864: Saving in-memory database to /data/mosquitto.db.
1596410864: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596410864: Error: No such file or directory.
1596412665: Saving in-memory database to /data/mosquitto.db.
1596412665: Error saving in-memory database, unable to open /data/mosquitto.db.new for writing.
1596412665: Error: No such file or directory.
