Problem showing local image on app for mobile notifications
I cannot get a locally stored image sent to my mobile notification. Is there anything I need to set permission wise somewhere?
I tried /config/www/lastsnap.jpg which works in lovelace. I can also set this one and I can pick it up using the media browser in lovelace: /media/snapshots/lastsnap.jpg
But it won’t work in app with or without speech marks. An external image like: https://raw.githubusercontent.com/home-assistant/assets/master/logo/logo.png works fine and in the past when I got that image from my camera directly it worked too. Any ideas welcome!
service: notify.mobile_app_vog_l09
  title: Campainha
  message: Ring Ring
    image: /config/www/lastsnap.jpg
    importance: high
    channel: doorbell_max
    clickAction: app://com.mcu.reolink
    vibrationPattern: 100, 1000, 100, 1000, 100
    actions:
      - action: URI
        title: View Image
        uri: lovelace/front
      - action: UNLOCK_DOOR
        title: Unlock Door
        uri: app://com.mcu.reolink
      - action: URI
        title: Live Stream
Can’t delete this, so I just had the lightbulb moment after a few days struggling…
it’s /local/snapshot.jpg as we reference a local file. Sorted!
you had to do anything special on the HA config to make this to work? I tried everything and can make this to work with a local image, if i use a hosted image works fine
thanks
share the code you used probably has something that needs to be adjusted
this is what I have now, for now i’m using the developers tools before to put the code in some automation, like i’ve said if I use a hosted image on the internet it works fine, i’m having trouble with local images, i’ve already whitelisted the directory and i’m able to use the images with other integrations like pushbullet without any issue, but with the mobile app is not working and also don’t see any log.
thanks
service: notify.mobile_app_phone12
  message: test
    image: images/front.jpg
image: images/front.jpg change this to image: /local/images/front.jpg
Then make sure the file is located in {config directory}/www/images/front.jpg
Anything in the www folder is actually considered local and the leading slash should be included
@peteonus I now have the same solution as @dshokouhi suggested.
using:
worked for me, thanks for your help
sorry didn’t see the notification on this… yes that’s it and my code as to send notification to phone:
image: /local/lastsnap.jpg
importance: high
actions:
  - action: URI
    title: View Image
    uri: lovelace/front
    title: Unlock Door
  - action: URI
    title: Live Stream
and this to set the image from the camera - note that I didn’t use local here but config/www which equates to the same as local:
service: camera.snapshot
  filename: /config/www/lastsnap.jpg
  entity_id:
    - camera.front_cam_profile000_mainstream
Hi, someone know why in the iphone can se the image, but on android 13 don´t?
I save the image here:
/media/facesnap/snap.jpg
and this is how i sended:
android:
service: notify.mobile_app_androidluis
data_template:
  title: Están Tocando el timbre...
  message: Esta persona esta tocando...
    color: red
    image: /media/local/facesnap/snap.jpg
iphone:
service: notify.mobile_app_iphone_hosi
data_template:
    color: red
Did you ever figure out a solution to this? iPhone receives image from my media folder but Android doesn’t.
