Problem starting connection with KNX
Hi everyone.
I’m new in HS and I’m trying to connect my ETS project with it, using a Logic controller (an spaceLynk) as Ip Router.
I’ve tried to make the same steps that are specificed here: “https://www.home-assistant.io/components/knx/”. However, I couldn’t connect it correctly. I’m modifying directly the configuration.yaml, I’m not using the XKNX lib yet.
Does anyone have some more documentation or could give me some steps for could end the process?
thanks!
