Problem to creating a scene or automation
Hey guys, I have a problem creating a scene or automation. The “bug”:
  • Automation setup timed out. The new automation was saved, but a timeout occurred while waiting for the setup.
  • Automation-Einrichtung mit Zeitüberschreitung. Neue(s) Automation wurde gespeichert, aber beim Warten auf die Einrichtung ist eine Zeitüberschreitung aufgetreten.
    what I have already done, directories deleted: automations.yaml, home-assistant_v2.db, scenes.yaml.
    Reload YAML configuration.
    So far, nothing has worked.
    I really hope someone can help me.
If you did that, you deleted any automation you managed to save.
Also these are files, not folders (or directories):
I have already deleted the content, the … .yaml files are all still there (content only).
Problem solved; the “configuration.yaml” file was missing “automation: !include automations.yaml”.
The same is valid for New scene timeout: you need “scene: !include scenes.yaml” in configuration.yaml.
