Currently I use the Docker container 0.106.6 in raspbian 10 on a Raspberry pi 4. Everything works well but as soon as I try to use the Docker Container homeassistant/raspberrypi4-homeassistant:stable (107.5 I think, but I also tried 107.2) homeassistant won’t start.
The only error I get is:
s6-mkdir: warning: unable to mkdir /var/run/s6: Permission denied
I can start all old containers but as soon as I want to start a 107.x Container this error occurs.
Any help is appreciated.
Thanks for your reply but I don’t think I will use root for the container. A smart home is a pretty sensible home infrastructure and people don’t have enough trust in using it as it is… Running stuff as root shouldn’t be the solution.
