I am having problems updating. I am trying to update from 0.92.1 to 0.93.0.
I click the update button in the hass.io section and the spinner spins and the Update button greys but after a while the update button briefly goes red then nothing happens. No update occurs.
19-05-17 00:35:11 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
19-05-17 00:35:11 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
19-05-17 00:35:11 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository
19-05-17 00:35:13 INFO (MainThread) [hassio.store] Load add-ons from store: 59 all - 0 new - 0 remove
19-05-17 02:35:11 INFO (MainThread) [hassio.snapshots] Found 8 snapshot files
19-05-17 02:35:11 INFO (MainThread) [hassio.host.info] Update local host information
19-05-17 02:35:11 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-05-17 02:35:11 ERROR (MainThread) [hassio.snapshots.snapshot] Can’t read snapshot tarfile /data/backup/._Hass_io_Partial_Before_New_Hassio.tar: invalid header
19-05-17 02:35:13 INFO (MainThread) [hassio.host.services] Update service information
19-05-17 02:35:13 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-05-17 05:41:38 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.93.0
19-05-17 05:41:38 INFO (SyncWorker_1) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.92.1 to homeassistant/raspberrypi3-homeassistant:0.93.0
19-05-17 05:41:38 INFO (SyncWorker_1) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.93.0.
19-05-17 05:41:53 ERROR (SyncWorker_1) [hassio.docker.interface] Can’t install homeassistant/raspberrypi3-homeassistant:0.93.0 -> 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”).
19-05-17 05:41:53 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
19-05-17 05:41:59 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.93.0
19-05-17 05:41:59 INFO (SyncWorker_8) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.92.1 to homeassistant/raspberrypi3-homeassistant:0.93.0
19-05-17 05:41:59 INFO (SyncWorker_8) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.93.0.
19-05-17 05:42:14 ERROR (SyncWorker_8) [hassio.docker.interface] Can’t install homeassistant/raspberrypi3-homeassistant:0.93.0 -> 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”).
19-05-17 05:42:14 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
19-05-17 05:42:20 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.93.0
19-05-17 05:42:20 INFO (SyncWorker_0) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.92.1 to homeassistant/raspberrypi3-homeassistant:0.93.0
19-05-17 05:42:20 INFO (SyncWorker_0) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.93.0.
19-05-17 05:42:35 ERROR (SyncWorker_0) [hassio.docker.interface] Can’t install homeassistant/raspberrypi3-homeassistant:0.93.0 -> 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”).
19-05-17 05:42:35 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
19-05-17 05:42:49 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.93.0
19-05-17 05:42:49 INFO (SyncWorker_5) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.92.1 to homeassistant/raspberrypi3-homeassistant:0.93.0
19-05-17 05:42:49 INFO (SyncWorker_5) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.93.0.
19-05-17 05:43:04 ERROR (SyncWorker_5) [hassio.docker.interface] Can’t install homeassistant/raspberrypi3-homeassistant:0.93.0 -> 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”).
19-05-17 05:43:04 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
19-05-17 05:43:29 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.93.0
19-05-17 05:43:29 INFO (SyncWorker_16) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.92.1 to homeassistant/raspberrypi3-homeassistant:0.93.0
19-05-17 05:43:29 INFO (SyncWorker_16) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.93.0.
19-05-17 05:43:44 ERROR (SyncWorker_16) [hassio.docker.interface] Can’t install homeassistant/raspberrypi3-homeassistant:0.93.0 -> 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”).
19-05-17 05:43:44 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
19-05-17 06:35:11 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
19-05-17 06:35:11 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository
19-05-17 06:35:11 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
19-05-17 06:35:13 INFO (MainThread) [hassio.store] Load add-ons from store: 59 all - 0 new - 0 remove
19-05-17 07:04:26 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.93.0
19-05-17 07:04:26 INFO (SyncWorker_10) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.92.1 to homeassistant/raspberrypi3-homeassistant:0.93.0
19-05-17 07:04:26 INFO (SyncWorker_10) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.93.0.
19-05-17 07:04:41 ERROR (SyncWorker_10) [hassio.docker.interface] Can’t install homeassistant/raspberrypi3-homeassistant:0.93.0 -> 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”).
19-05-17 07:04:41 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
19-05-17 07:09:42 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.93.0
19-05-17 07:09:42 INFO (SyncWorker_15) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.92.1 to homeassistant/raspberrypi3-homeassistant:0.93.0
19-05-17 07:09:42 INFO (SyncWorker_15) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.93.0.
19-05-17 07:09:57 ERROR (SyncWorker_15) [hassio.docker.interface] Can’t install homeassistant/raspberrypi3-homeassistant:0.93.0 -> 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”).
19-05-17 07:09:57 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
Just an idea (complete noob here) are your hassio IP settings configured correctly?
Had similar problems once (couldnt update and add-on store was acting strange) when my router mac binding was different than the settings i had loaded to the hassio through usb. I had some internet connectivity but not everything was working.
