I have installed version 2023.2.5 and trying to upgrade to Latest version 2023.3.4 but getting errors
23-03-14 16:05:36 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 2023.3.4
23-03-14 16:05:36 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.2.5 to ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.3.4
23-03-14 16:05:36 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant with tag 2023.3.4.
23-03-14 16:21:14 WARNING (MainThread) [supervisor.misc.tasks] Watchdog/Application found a problem with observer plugin!
23-03-14 16:21:34 INFO (SyncWorker_4) [supervisor.docker.interface] Stopping hassio_observer application
23-03-14 16:23:29 INFO (SyncWorker_4) [supervisor.docker.interface] Cleaning hassio_observer application
23-03-14 16:23:29 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
23-03-14 16:25:00 INFO (SyncWorker_0) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2021.10.0 - 172.30.32.6
23-03-14 16:27:47 ERROR (SyncWorker_2) [supervisor.docker.interface] Can’t install ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.3.4: 404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.3.4/json: Not Found (“no such image: ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.3.4: No such image: ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.3.4”)
23-03-14 16:27:47 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
