Problem while starting z2m
Since this morning, I’m having an issue with Zigbee2mqtt. The broker is working properly but z2m add-on doesn’t start anymore. Does anyone know how to fix this issue? Thanks!
Here is my configuration:
Try adding the next line to the serial part of the configuration.
adapter: ember
Also take a look at: Improved Ember (EZSP) driver (experimental) · Koenkk/zigbee2mqtt · Discussion #21462 · GitHub
Thanks for the advice
