Problem with Actron add-on after latest HA Update
I’m not sure where to put this request for help so Im just going to try here.
I have a working add-on for My Actron AC that was up until recently working fine. Yesterday I updated to the latest HA and found that I needed to go into the add-on and “restart” it for me to be able to see the controls again. I thought this was just a once off problem but unfortunately after the restart it only works for about 10 minutes then stops again and this is the information I am getting from the Log of the Addon.
“27-02-2024 10:07:40.36 MQTT.SendMessage() hass-actron/status
27-02-2024 10:08:00.38 AirConditioner.CheckLastUpdate() No communication with Actron unit (Default) for at least 5 minutes. Check Actron Connect unit can connect to the network and locate the add-on.”
On checking the MQTT log, there is no problem showing.
Any suggestions on this would be great as this add-on is the only one that can work with my Actron Air Conditioner installation.
Ian
If you are having a problem with a specific AddOn, the first point of contact is in the Github post that you found it in originally.
Most if not all the people there that know the product and use the software that will be able to give you more accurate information regarding your problem.
Here you might find someone.
Thanks I looked at that first but there really has been nothing on the GitHub site for a long time and seeing as it has only started very recently (after working great for years) I wanted to see if anyone else may have had a similar issue.
I’ll continue searching.
Ian
Add an issue anyway on that site. It’s your best bet.
I’m also experiencing the same issue. Might need to log this on git hub
