Problem with adding one unit RFXTRX
I have used the RFXcomidgenerator (https://github.com/Sennevds/RFXcomIdGenerator) to generate the id’s for my devices because i don’t have anymore the remote.
Now i have some problems with adding the unit with housecode K and unitcode 17.
Result from script: 071002004B0170000
When i add this to configuration.yaml i receive error: homeassistant.components.rfxtrx] Invalid device:
When add a device with housecode K and unitcode 3 for example this is working.
Result from script: 071002004B040000
I see there is some difference in lenght of the result but don’t know what it should be.
Thanks in advance.
there is one zero too much added.
Lighting1 command: 07 10 02 0F 4B 17 00 00
Packettype = Lighting1
subtype = ELRO AB400
Sequence nbr = 15
housecode = K
unitcode = 23
Command = Off
Signal level = +10 dBm
Lighting1 command: 07 10 02 10 4B 17 01 00
Sequence nbr = 16
housecode = K
unitcode = 23
Command = On
That was the trick.
Only unit code was 17 so triggered me it had to be hexadecimal.
Final off code is: 07 10 02 0F 4B 11 00 00
