Problem with automation between KNX and light.turn_on
i have the following problem.
I have an automation to turn on a Shelly switch from KNX
For example:
in configuration.yaml:
binary_sensor:
    - name: "knx_beleuchtung_test_schalten"
      state_address: "0/1/1"
This is my Trigger for automation
Here the automation for switching on and off.
 alias: Sophie_Bett_WLED_schalten_AN
  description: ''
  triggers:
  - entity_id:
    - binary_sensor.knx_beleuchtung_test_schalten
    to:
    - 'on'
    trigger: state
  conditions: []
  actions:
  - data: {}
    action: light.turn_on
      entity_id: light.sophie_wled_sophie
  mode: single
- id: '1786544827265'
  alias: Sophie_Bett_WLED_schalten_AUS
  description: ''
  triggers:
  - entity_id:
    to:
    - 'off'
    trigger: state
  conditions: []
  actions:
  - action: light.turn_off
      entity_id:
      - light.sophie_wled_sophie
    data: {}
  mode: single.
Works so far.
But my problem is that this automation doesn’t run reliably.
As long as I control everything solely via KNX, it works well; however, whenever I control it via Home Assistant or directly through the Shelly app, the On/Off command no longer works reliably.
The problem is, for example:
If I switch it on via KNX and then switch it off in the Shelly app, I cannot immediately send another “on” command via KNX—it simply doesn’t work. I first have to switch it off via KNX before I can switch it on via KNX again.
I think it’s because of that.
    **to:**
    - 'on'
When I control it via Home Assistant or the Shelly app, the value of the entity “knx_beleuchtung_test_schalten” does not change, and unfortunately, the command only works when that value changes.
Is there a way to work around this—or to ensure the command always executes whenever the entity “knx_beleuchtung_test_schalten” sends a value of “1”?
I would be grateful for any help.
Hi :waving_hand:!
You’d need to send state updates back to Knx so the switch knows to send an ON or OFF when you tap it. That’s a common Knx practice mostly done via a separate status group address.
If you use the knx.telegram trigger, you can remove the binary sensor.
There are some blueprints that do all of that for you Topics tagged knx
