Hi, im trying to add a couple of lines to my config.yaml but im getting the red circle with an explanation mark stopping me from doing so.
Im thinking its something to do with the previous template that i have made? - but just a guess. Is it possible to have two templates one after another?
My yaml file is below, please scroll to the bottom.
Im completely new to ha, but have managed to get things working for my inverter, and now trying to capture data from a shunt using a wemos d1 mini over mqtt…
(Home Assistant + Tasmota (Wemos mini R1) + Battery meter KG140F - #23 by Catchmydrift )
Im trying to add these lines:
template:
- trigger:
- platform: mqtt
topic: tele/D1_mini_1/RESULT
But cant even add the first line ‘template’… Presumably due to the previous template? - of so, how do i end a template to add a fresh new one?
Thank you
petro
(Petro)
June 13, 2023, 6:58pm
2
You need to format your code. It looks like jibberish if you don’t. Use 3 backticks before your code and 3 backticks after your code. This is a backtick `. If you have an american keyboard, it shares the same button as ~. Edit your original post and format it. Do not copy from your original post and paste as it will retain the incorrect format.
However, even without formatting I can tell you’re trying to add a template: section at the bottom of your file when you already have a template section. That is not possible, your code needs to go in the template section. Make sure you don’t also paste the word template:
into your template:
section.
Thanks very much, that really helped . (ive added my yaml file below, the spaces may be slightly wrong at the line - trigger
and below, as added them in a minute ago as i Deleted them for the moment)
The syntax is correct now, but unfortunately i get this error in the logs:
Logger: homeassistant.config
Source: config.py:982
First occurred: 8:21:48 PM (3 occurrences)
Last logged: 8:23:50 PM
Invalid config for [template]: [trigger] is an invalid option for [template]. Check: template->sensor->3->trigger. (See /config/configuration.yaml, line 183).
Invalid config for [template]: [trigger] is an invalid option for [template]. Check: template->sensor->3->trigger. (See /config/configuration.yaml, line 180).
Any ideas much appreciated
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24
modbus:
- name: epever
type: rtuovertcp
host: 192.168.0.188
port: 8088
delay: 5
timeout: 10
close_comm_on_error: false
retry_on_empty: true
retries: 20
sensors:
# Utility
- name: "Grid Voltage"
unit_of_measurement: V
slave: 10
address: 0x3500
input_type: input
scale: 0.01
precision: 2
- name: "Grid Current"
unit_of_measurement: A
slave: 10
address: 0x3501
input_type: input
scale: 0.01
precision: 2
- name: "Grid State"
# 0:Normal, 1:Low input; 2:High input, 3: No connected
slave: 10
address: 0x3511
input_type: input
- name: "Grid Total"
unit_of_measurement: kWh
slave: 10
address: 0x350F
input_type: input
scale: 0.01
precision: 2
data_type: int32
swap: word
count: 2
# PV Array
- name: "PV Voltage"
slave: 10
address: 0x3549
input_type: input
scale: 0.01
precision: 2
- name: "PV Current"
slave: 10
address: 0x354A
input_type: input
scale: 0.01
precision: 2
- name: "PV Power"
unit_of_measurement: W
slave: 10
address: 0x354B
input_type: input
scale: 0.01
precision: 2
data_type: int32
swap: word
count: 2
- name: "PV Total"
slave: 10
address: 0x3557
input_type: input
scale: 0.01
precision: 2
data_type: int32
swap: word
count: 2
# Load
- name: "Load Voltage"
slave: 10
address: 0x3521
input_type: input
scale: 0.01
precision: 2
- name: "Load Current"
slave: 10
address: 0x3522
input_type: input
scale: 0.01
precision: 2
- name: "Load Total"
slave: 10
address: 0x3530
input_type: input
scale: 0.01
precision: 2
data_type: int32
swap: word
count: 2
# Battery
- name: "Battery Voltage"
slave: 10
address: 0x3580
input_type: input
scale: 0.01
precision: 2
- name: "Battery Current"
slave: 10
address: 0x3581
input_type: input
scale: 0.01
precision: 2
- name: "Battery Capacity"
unit_of_measurement: "%"
slave: 10
address: 0x3586
input_type: input
scale: 1
- name: "Battery Temp"
#ElectricChrgBatteryTemp
unit_of_measurement: "°C"
slave: 10
address: 0x3512
input_type: input
scale: 0.01
- name: "Battery State"
# 0:Normal, 1:Overvoltage, 2:Undervoltage, 3:Undervoltage Disconnect, 4:Fault
slave: 10
address: 0x3589
input_type: input
- name: "Charging Mode"
# 1:Solar Priority, 2:Utility & Solar, 3:Solar
slave: 10
address: 0x9607
input_type: holding
- name: "Inverter Mode"
# 0:Inverter priority, 1:Utility Priority
slave: 10
address: 0x9608
input_type: holding
- name: "Inverter Temp"
#LoadHeatSink2Temp
slave: 10
address: 0x3533
input_type: input
scale: 0.01
template:
- name: "Grid Power"
device_class: power
state: "{{((states('sensor.grid_current')| float(0) * states('sensor.grid_voltage')| float(0))) | round(2) }}"
- name: "Power into batt"
state: "{{ states('sensor.grid_power') | float + states('sensor.pv_power') | float }}"
device_class: power
- name: "House Load"
device_class: power
state: "{{((states('sensor.load_current')| float(0) * states('sensor.load_voltage')| float(0))) | round(2) }}"
- trigger:
- platform: mqtt
- name: Temperatura
state: "{{ (trigger.payload.split(',')[9] | float-100) }}"
- name: Tensione
unit_of_measurement: "V"
state: "{{ (trigger.payload.split(',')[3] | float/100) }}"
- name: Corrente
unit_of_measurement: "A"
state: "{{ (trigger.payload.split(',')[4] | float/100) }}"
- name: Potenza
unit_of_measurement: "W"
state: "{{ (trigger.payload.split(',')[6] | float/100) }}"
- name: Capacità
state: "{{ (trigger.payload.split(',')[5] | float/11000*100) }}"
- name: Consumato
unit_of_measurement: "kWh"
state: "{{ (trigger.payload.split(',')[6] | float/10000) }}"
- platform: integration
source: sensor.house_load
unit_prefix: k
round: 2
petro
(Petro)
June 13, 2023, 8:44pm
5
The letter t in trigger should line up with the indentation level for a in sensor. Also, the previous sensor will need a dash before it.
Thanks for your help, but when formatted correctly like you say above, i still get this in logs:
First occurred: 7:22:27 PM (1 occurrences)
Last logged: 7:22:27 PM
Sorry, do you mean config.yaml? If so:
default_config:
frontend:
# Text to speech
tts:
http:
trusted_proxies:
- 172.30.33.0/24
modbus:
- name: epever
type: rtuovertcp
host: 192.168.0.188
port: 8088
delay: 5
timeout: 10
retries: 20
sensors:
# Utility
slave: 10
address: 0x3500
input_type: input
scale: 0.01
precision: 2
slave: 10
address: 0x3501
input_type: input
scale: 0.01
precision: 2
slave: 10
address: 0x3511
input_type: input
slave: 10
address: 0x350F
input_type: input
scale: 0.01
precision: 2
data_type: int32
swap: word
count: 2
# PV Array
slave: 10
address: 0x3549
input_type: input
scale: 0.01
precision: 2
slave: 10
address: 0x354A
input_type: input
scale: 0.01
precision: 2
- name: "PV Power"
slave: 10
address: 0x354B
input_type: input
scale: 0.01
precision: 2
data_type: int32
swap: word
count: 2
- name: "PV Total"
slave: 10
address: 0x3557
input_type: input
scale: 0.01
precision: 2
data_type: int32
swap: word
count: 2
# Load
slave: 10
address: 0x3521
input_type: input
scale: 0.01
precision: 2
slave: 10
address: 0x3522
input_type: input
scale: 0.01
precision: 2
slave: 10
address: 0x3530
input_type: input
scale: 0.01
precision: 2
data_type: int32
swap: word
count: 2
# Battery
slave: 10
address: 0x3580
input_type: input
scale: 0.01
precision: 2
slave: 10
address: 0x3581
input_type: input
scale: 0.01
precision: 2
slave: 10
address: 0x3586
input_type: input
scale: 1
slave: 10
address: 0x3512
input_type: input
scale: 0.01
slave: 10
address: 0x3589
input_type: input
slave: 10
address: 0x9607
input_type: holding
slave: 10
address: 0x9608
input_type: holding
#LoadHeatSink2Temp
slave: 10
address: 0x3533
input_type: input
scale: 0.01
template:
- sensor:
device_class: power
device_class: power
device_class: power
- trigger:
- platform: mqtt
unit_prefix: k
round: 2
By adding the trigger lines, it stops ‘grid power’ and ‘house load’ sensors from working now also…
petro
(Petro)
June 14, 2023, 7:06pm
9
Well that’s even worse than your last attempt.
Using your last attempt…
Notice the red line, that’s the indentation level. Hopefully my explanation makes sense now.
Thanks . Its working now …
Ive pasted in some other lines, and the data shows up in HA
default_config:
frontend:
# Text to speech
tts:
http:
trusted_proxies:
- 172.30.33.0/24
modbus:
- name: epever
type: rtuovertcp
host: 192.168.0.188
port: 8088
delay: 5
timeout: 10
retries: 20
sensors:
# Utility
slave: 10
address: 0x3500
input_type: input
scale: 0.01
precision: 2
slave: 10
address: 0x3501
input_type: input
scale: 0.01
precision: 2
slave: 10
address: 0x3511
input_type: input
slave: 10
address: 0x350F
input_type: input
scale: 0.01
precision: 2
data_type: int32
swap: word
count: 2
# PV Array
slave: 10
address: 0x3549
input_type: input
scale: 0.01
precision: 2
slave: 10
address: 0x354A
input_type: input
scale: 0.01
precision: 2
- name: "PV Power"
slave: 10
address: 0x354B
input_type: input
scale: 0.01
precision: 2
data_type: int32
swap: word
count: 2
- name: "PV Total"
slave: 10
address: 0x3557
input_type: input
scale: 0.01
precision: 2
data_type: int32
swap: word
count: 2
# Load
slave: 10
address: 0x3521
input_type: input
scale: 0.01
precision: 2
slave: 10
address: 0x3522
input_type: input
scale: 0.01
precision: 2
slave: 10
address: 0x3530
input_type: input
scale: 0.01
precision: 2
data_type: int32
swap: word
count: 2
# Battery
slave: 10
address: 0x3580
input_type: input
scale: 0.01
precision: 2
slave: 10
address: 0x3581
input_type: input
scale: 0.01
precision: 2
slave: 10
address: 0x3586
input_type: input
scale: 1
slave: 10
address: 0x3512
input_type: input
scale: 0.01
slave: 10
address: 0x3589
input_type: input
slave: 10
address: 0x9607
input_type: holding
slave: 10
address: 0x9608
input_type: holding
#LoadHeatSink2Temp
slave: 10
address: 0x3533
input_type: input
scale: 0.01
template:
- sensor:
device_class: power
device_class: power
device_class: power
- trigger:
- platform: mqtt
- name: Temperatura
- name: Tensione
- name: Corrent
- name: Potenza
- name: Capacità
- name: Consumato
unit_prefix: k
round: 2
