dyson:
username: userid
password: password
language: GB (I've also tried SE for Sweden where I live)
devices:
- device_id: XXX-XX-XXXXXXXX
device_ip: 192.168.1.nnn
But I only get: Unable to find device XXX-XX-XXXXXXXX in Dyson account
I can see the unit in my Dyson app but not on “My Dyson”. I’ve spoked with Dyson and they can see that the unit is registered. (When I tried to register it on the web it says: serial no invalid)
No, not yet. It seems like TP04 and DP04 models are working but not the HP04. At least not now.
Can you see your unit if you log into “My Dyson” on the web? I cannot see mine but when I call Dyson they can see that it is registered but for some reason does not yet show up on “My Dyson”.
I will check that myself later this evening. I can however not see my unit when I logg into any of the My Dyson accounts (Sweden or USA). The helpdesk at Dyson in Sweden say that they can see the unit registered on me but I cannot see it myself for some reason.
When I try to register the unit, I get “invalid serial number”.
I just sent them an email to see if they can support in any way.
Absolutely. Just tried to see if I got the same error codes as you and I did. When trying with SE for Sweden I got “not connected” and when trying GB i got “unable to find device”.
I have registered a My Dyson account on both dyson.se and dyson.com and since I have different passwords on them I could conclude that HA is only trying the account registered on dyson.com.
I keep you informed when I get more info.
I had my Dyson fan working in NL, for about a month.
After an update or reboot I kept getting this error: “Not connected to Dyson account. Unable to add devices”
I found out (for the second time) that the account in the app and on the website are two different accounts. I reset the password for the app, logged in and setup the fan in the app. When I put the password I used in the app in HA the connection error disappeared and I’m able to control my fan.
Probably some error on my end in my case, but maybe you can use the info.
