Problem with connection on HassOS
My Rasberry pi3 B+ with hassOS doesn’t reboot after i made some changes to install the repository dasshio https://github.com/danimtb/dasshio i’ve experienced this broblem before but this time im unable to connect to hassio via samba share or SSH i only want to bakup all of my files because i have more then 25 devices set up in the configuration folder and i don’t want to setup it again.
If anyone have a good idea please leve me a reply?
I give a thanks to all that are helping me to solve this problem.
Take your SD card out and connect it to a computer running Linux (Ubuntu for example). There you will be able to see all partitions and you will be able to find your configuration files.
where i can finde the configuration.yaml under which folder??
