Hi, I’m new to HA and I try to setup an overview of my energy flows. I have the following yaml file:
type: custom:power-flow-card-plus
entities:
battery:
entity: sensor.sigen_inverter_battery_power
state_of_charge: sensor.sigen_inverter_battery_state_of_charge
show_state_of_charge: true
invert_state: true
color_value: true
use_metadata: true
display_state: two_way
state_of_charge_decimals: 2
grid:
entity: sensor.p1_meter_vermogen
color_icon: color_dynamically
color_circle: color_dynamically
use_metadata: false
secondary_info:
entity: sensor.net_co2_vrij_percentage_2
color_value: true
display_zero: true
accept_negative: true
unit_of_measurement: '%'
solar:
entity: sensor.solaredge_i1_ac_power
color_value: true
color_icon: true
invert_state: false
secondary_info:
entity: sensor.solaredge_i1_dc_power
color_value: false
sum_total: true
display_zero: false
unit_white_space: true
display_zero: true
use_metadata: false
home:
entity: sensor.netto_huisverbruik
use_metadata: false
subtract_individual: false
override_state: true
individual:
- entity: sensor.evac_laadvermogen
icon: mdi:ev-station
secondary_info:
entity: sensor.evac_geladen_energie_kwh
decimals: 0
display_zero: true
unit_of_measurement: kWh
decimals: 1
- entity: sensor.berging_cu401b_s_warmtepomp_actueel_vermogen
icon: mdi:heat-pump
display_zero: true
secondary_info:
entity: sensor.berging_cu401b_s_warmtepomp_totaal_verbruik
display_zero: true
color_value: false
color_icon: true
color_value: true
clickable_entities: true
display_zero_lines: true
use_new_flow_rate_model: true
base_decimals: 0
kilo_decimals: 2
min_flow_rate: 0.75
max_flow_rate: 6
max_expected_power: 2000
min_expected_power: 0.01
kilo_threshold: 1000
mega_threshold: 1000000
transparency_zero_lines: 0
sort_individual_devices: false
grid_options:
columns: full
But I have the following problems:
- home consumption is 0 W which is not correct
- the heatpump is not visible
Any help is appreciated,
Tx/Alain
