I have the portal web page pulled up on another tab. When I change the card from none to away and back to none, the portal changes from following schedule to permanent hold and back to following schedule. But when I use the action to change from none to away to none, no change is seen in the portal. In short, the card is communicating with the portal, but the action is not. Here is the yaml for the action, in a script:
Thanks; I made that change. I also learned that the Honeywell integration can be slow to respond so a repeat-until loop is suggested. now it looks like this:
