Problem with light.group, responses / commands are very slow
i am using a light.group to switch my garden lights (5x) but apparently there is a problem i have encountered.
The lamps react very slowly or not at all when I switch the group on and off or change the color of the bulbs, for example.
I tested the whole thing under services under developer tools, if I switch a bulb of the group on/off there, it works within 1-2 seconds.
If I switch the whole group there now, it takes about 10 seconds until they are all on, although sometimes individual bulbs do not go on or off.
I have connected the lamps to the deconz, now I have already searched a bit and have also come across several contributions on the subject, but they are all from February and a solution was not there either.
can you create groups in deconz yourself? that is better?
or how to get around this?
here is my light.group in my configuration.yaml
light:
  - platform: group
    entities:
      - light.garten1
      - light.garten_steinbeet
      - light.garten_kugel
      - light.garten_rosen
      - light.garten_schuppen
and my setup
Home Assistant Core 2022.6.6
Home Assistant Supervisor 2022.05.3
Home Assistant OS 8.2
and my deconz map
In zigbee2mqtt it is definitely better to create the group on the coordinator rather than ha. I guess deconz will likely be the same.
