Problem with met.no and Hassio+Docker
Hey!
I’m new to Community and today I try to install Hassio+Docker on Raspbian Buster (on Virtual Machine).
I see my hassio on LAN but when I access to hassioip:8123 I see “unknwon” about my weather forecast (other functions work without problems… I install some addons like “File Editor”, “SSH Terminal”, “Google Drive Backup”, …).
From log, I see: https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/1.9/ returned Cannot connect to host aa015h6buqvih86i1.api.met.no:443 ssl:None (try again)
But from my real-machine I get that URL without problem.
Have you got any ideas?
Thanks!
Wait 20 minutes and it will be connected. I see this error always when restarting my test-HA.
Thanks, but I have the same error:
2020-04-22 09:10:25 ERROR (MainThread) [metno] https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/1.9/ returned Cannot connect to host aa015h6buqvih86i1.api.met.no:443 ssl:None [Try again]
2020-04-22 09:10:25 ERROR (MainThread) SAME_ERROR ( --> I can’t insert more 2 links) ssl:None [Try again]
2020-04-22 09:25:31 ERROR (MainThread) SAME_ERROR ( --> I can’t insert more 2 links) ssl:None [Try again]
Maybe, is it a problem(s) about my Virtual Machine (Network Configurations, …)? But I can access to my VM on LAN…
