I have a Tasmota Modbus EIA-485 RS-485 TCP MQTT HTTP UART module with 5-12V RS485 WiFi Bridge and would like to integrate it into the HA using a Modbus network. The goal is to read the data from the heating boiler. It only supports Modbus.
- TCP Bridge, port (502), and TCP Socket are configured
- The module is accessible via a fixed IP (192.168.123.11)
- Communication: rpuovertcp
I created the following YAML file:
modbus:
- name: modbus_hub
type: rtuovertcp
host: 192.168.123.11
port: 502
sensors:
- name: "boiler temperature actual"
unique_id: boiler_temp_actual
slave: 1
address: 2347
input_type: holding
data_type: int16
unit_of_measurement: "°C"
device_class: temperature
state_class: measurement
scan_interval: 10
Unfortunately, I don’t see either the device or entities.Shouldn’t HA also find the board? What’s going wrong here?
