Problem with MQTT sensors after splitting configuration
Hello all,
Like the title says im having some trouble with MQTT sensors after i have been splitting the configuration.yaml.
Simultaneously i have tried to format the mqtt sensors to its new formatting.
The entities which would work before splitting are no longer available?
So in the configuration.yaml i have this:
mqtt: !include_dir_merge_list mqtt/
I have added in a directory mqtt in the root folder
In that folder there are different .yaml files for a certain group of mqtt sensors
Content of one of the files:
    - name: "Schuur Temperatuur"
      state_topic: "RFX433/Schuur/"
      unit_of_measurement: "°C"
      value_template: '{{ value_json["Temperature"] }}'
    - name: "Schuur Luchtvochtigheid"
      unit_of_measurement: "%"
      value_template: "{{ value_json.Humidity }}"
Sure thing i have missed something during the splitting but i cant seem to find out what.
Other sensors like template sensors are working fine?
I hate to do this but has anyone any ideas? :flushed:
Anything in the logs?
indentation perhaps? In the content you quoted above the “sensor:”-line is already indented with two spaces, not 100% sure but I think that should start in column 1 ?
Armin
Hi Armin,
No only things that are a result of the entities not being there.
Tried to modify the identations but still nothing. :frowning:
Does it pass a check config from the developer tools?
If this is across several files, I’d move the mqtt: in to the files so each file looks correct independently then just use a straight include in configuration.yaml
Hi eightiescalling,
Yes it does pass the check config, which would indicate to be ok.
When i copy the mqtt to the configuration file it self it works instantly?
Problem solved thanks to the discord channel.
Configuration.yaml:
mqtt:
  sensor: !include_dir_merge_list mqtt/sensors/
mqtt/sensors/sensor.yaml
For the wizzkids among us seems like i was trying to fill a dictionary with a list and that doesn’t work.
Very big shout out to @Tinkerer
