Problem with publish_state for template binary sensor
Last year, I built a smart mailbox that tells me when I have mail. At some point this year, it stopped working. Specifically, the one MQTT topic that gives a simple binary answer to the question ‘Got mail?’ seems to have stopped publishing. Everything else seems to work just fine. I’ve even checked MQTT Explorer and the topic just doesn’t seem to be written, despite the logs from the ESP32 saying it’s publishing it.
I’m pulling my hair out trying to see what’s wrong. Sorry to dump the whole script here, but if anyone has some insight or suggestions how to proceed, please let me know.
substitutions:
  devicename: "smart-mailbox"
  sub_ota: "1"
  sub_sun: "2"
  upd_prox1: "1"
  upd_prox2: "2"
  upd_adc: "4"
esphome:
  on_boot:
    - priority: -300
      then:
        - script.execute: check_stuff
esp32:
  board: esp32dev
  framework:
    type: esp-idf
wifi:
  ssid: !secret wifi_ext_ssid
  power_save_mode: LIGHT
  fast_connect: true
  ap:
    ssid: "Smart Mailbox Fallback Hotspot"
    password: !secret ota_smart_mailbox
# captive_portal:
# Enable logging
logger:
  level: DEBUG
  # baud_rate: 0
  # level: NONE
# Enable API
# api:
# Enable MQTT
mqtt:
  broker: !secret mqtt_broker
  username: !secret mqtt_username
  password: !secret mqtt_password
  birth_message:
  will_message:
ota:
  - platform: esphome
    on_end:
      then:
        - lambda: |-
            id(ota_mode) = 0;
            id(got_mail) = 0;
        - mqtt.publish:
            topic: "$devicename/ota"
            payload: "OFF"
            retain: true
        - lambda: |-
            id(ota_ready).publish_state(false);
            id(got_mail).publish_state(false);
globals:
  - id: updates
    type: int
    restore_value: no
    initial_value: '0'
  - id: subscriptions
    type: int
    restore_value: no
    initial_value: '0'
  - id: ota_mode
    type: int
    restore_value: no
    initial_value: '0'
  - id: sun_status
    type: std::string
    restore_value: no
    initial_value: '"unknown"'
  - id: naptime
    type: int
    restore_value: no
    initial_value: '300'
deep_sleep:
i2c:
  - id: bus_a
    sda: 21
    scl: 22
  - id: bus_b
    sda: 25
    scl: 26
external_components:
  source: github://dixonte/esphome-vcnl4010
  components: [vcnl4010_i2c_sensor]
script:
  - id: check_stuff
    then:
    # Announce device is online
    - mqtt.publish:
            topic: "$devicename/status"
            payload: "online"
            retain: true
    # Get status from Home Assistant
    - lambda: |-
        id(mqtt_cli).subscribe("$devicename/ota", [=](const std::string &topic, const std::string &payload) {
          ESP_LOGD("mqtt", "Received OTA status: %s", payload.c_str());
          auto previous_ota = id(ota_mode);
          id(ota_mode) = (payload.compare("ON") == 0);
          id(subscriptions) |= $sub_ota;
          if (!id(ota_mode) && previous_ota) {
            ESP_LOGD("mailbox", "OTA mode aborted, going into immediate microsleep...");
            id(sleepy).set_sleep_duration(1000);
            id(sleepy).begin_sleep(true);
        id(mqtt_cli).subscribe("sun/status", [=](const std::string &topic, const std::string &payload) {
          ESP_LOGD("mqtt", "Received sun status: %s", payload.c_str());
          id(sun_status) = payload;
          id(subscriptions) |= $sub_sun;
    # Wait for status from Home Assistant
    - wait_until:
        lambda: |-
          return (id(subscriptions) == ($sub_ota | $sub_sun));
    # How long should we sleep after updating?
    - lambda: |-
        if (id(sun_status) == "above_horizon") {
          id(naptime) = 60; //600;
        } else if (id(sun_status) == "below_horizon") {
          id(naptime) = 3600;
        } else {
          id(naptime) = 60;
    # Update sensors
    - lambda: |-
        ESP_LOGD("mailbox", "Updating sensors");
        id(sensor1).update();
        id(sensor2).update();
        id(lastUpdate).update();
        id(bat_voltage_raw).set_update_interval(1300);
        id(bat_voltage_raw).start_poller();
    # Wait for updates
    - wait_until:
        lambda: |-
          return (id(updates) == ($upd_prox1 | $upd_prox2 | $upd_adc));
    # Do we have mail?
    - lambda: |-
        //bool gotMail;
        if ((id(prox1).state > 30000) || (id(prox2).state > 30000)) {
          //gotMail = true;
          ESP_LOGD("mailbox", "Publishing got mail state: You've got mail");
          id(got_mail).publish_state(true);
        } else {
          //gotMail = false;
          ESP_LOGD("mailbox", "Publishing got mail state: No mail is good mail");
        //ESP_LOGD("mailbox", "Publishing got mail state: %d", gotMail);
        //id(got_mail).publish_state(gotMail);
    - delay: 1s
    - logger.log:
        format: "Sleeping for %d seconds | OTA: %d"
        args: [ 'id(naptime)', 'id(ota_mode)' ]
    # Shut down indefinitely if battery low
    - if:
        condition:
          lambda: 'return (id(bat_voltage).state < 3.1);'
        then:
          - mqtt.publish:
                  payload: "offline"
                  retain: true
          - deep_sleep.enter:
              sleep_duration: 3650d
    # Deep sleep to save battery, if not OTA mode
    - if:
        condition:
          lambda: 'return id(ota_mode) == 0;'
        then:
          - deep_sleep.enter:
              sleep_duration: !lambda |-
                  return id(naptime) * 1000;
        else:
          - lambda: |-
              ESP_LOGD("mqtt", "OTA ready.");
              id(ota_ready).publish_state(true);
button:
    on_press:
      - logger.log: Checking mail on demand
      - component.update: sensor1
      - component.update: sensor2
  - platform: vcnl4010_i2c_sensor
    i2c_id: bus_a
    update_interval: never
    proximity:
      name: Proximity sensor 1
      on_value:
        lambda: |-
          id(updates) |= $upd_prox1;
    # ambient:
    #   name: Light sensor 1
    i2c_id: bus_b
    proximity:
      name: Proximity sensor 2
      on_value:
        lambda: |-
          id(updates) |= $upd_prox2;
    # ambient:
    #   name: Light sensor 2
  - platform: adc
    pin: 33
    name: "Battery voltage (raw)"
    accuracy_decimals: 3
    attenuation: auto
    # filters:
    #   - sliding_window_moving_average:
    #       window_size: 30
    #       send_every: 5
    #       send_first_at: 1
    filters:
      - median:
          window_size: 10
          send_every: 10
          send_first_at: 10
    on_value:
      lambda: |-
        id(bat_voltage_raw).stop_poller();
        id(bat_voltage).update();
        id(bat_percentage).update();
        id(updates) |= $upd_adc;
    unit_of_measurement: 'V'
    icon: "mdi:battery"
    lambda: |-
      return ((360.0f * id(bat_voltage_raw).state) + (1000.0f * id(bat_voltage_raw).state)) / 1000.0f;
    unit_of_measurement: '%'
    icon: "mdi:battery-check"
    lambda: |-
      return id(bat_voltage).state;
    filters:
      - calibrate_linear:
        - 3.1 -> 0
        - 4.2 -> 100
    icon: "mdi:timer-sand-complete"
    state_class: "measurement"
    accuracy_decimals: 1
    lambda: |-
      return millis();
binary_sensor:
    icon: mdi:mailbox
    icon: mdi:download
Further testing suggests that mqtt.publish isn’t working for me, either. The $devicename/status is not being written to MQTT.
So… any specific reason why you use MQTT and not just the normal API ESP-Home uses?
Seems that could solve your problems quite easily
what about turning this into
topic: ${devicename}/status
since you didn’t define a substituation named “devicename/status”
Mainly it’s part of making it so the device can sleep for long periods without appearing offline to HA. That’s the idea, at least.
I’ll try that
So I seem to have worked around the issue, hopefully?
By a combination of adding this at the start of my script: tag
    # Wait for MQTT
    - wait_until:
        condition:
          mqtt.connected:
and manually adding this after the lambda that updates got_mail
    - mqtt.publish:
        topic: "${devicename}/binary_sensor/got_mail_/state"
        payload: !lambda |-
          if (id(got_mail).state)
            return "ON";
          else
            return "OFF";
