Problem with scene
Hello
Wrote a script to turn on the light depending on the state of the opening sensor.
alias: light_auto
initial_state: true
platform: state
entity_id: binary_sensor.ofis_dver_vkhodnaia_73
to: 'on'
service: light.turn_on
entity_id: light.unknown_rele_7_1753
When checking the configuration, everything is successful. I reset the automation
but when the Sensor is triggered, the light does not turn on
the light does not turn on manually when starting the scene
Is that automation passing Config Check?
Correct formatting should look like this:
- alias: light_auto
  initial_state: true
    platform: state
    to: 'on'
Please check your indentation. And please try to follow the posting guidelines. Use the ctrl+shift+c when posting your yaml code, so it preserves the correct indentation like this:
          alias: light_auto
          initial_state: true
            platform: state
            to: 'on'
Can you confirm that you can manually send the service command light.turn_on to the referenced entity_id: light.unknown_rele_7_1753 ?
