Problem with scripts in automation
Im having some problems with my "morning automation". The last few days, it hasnt worked as it should.
But I think I might have found the problem, but not a solution for it.
The very first action is a script that controls a heatpump.
In the script I have a delay for 1 hour.
And now I`m thinking that action nr2 waits for the entire script to run (am I right ?)
If this is right, how do I make the automation continue while the script is still running?
Check the last section: Scripts - Home Assistant.
TL;DR: Use script.turn_on.
Thank you ! Did not know of this.
Now I`ll go over all my other automations :slight_smile:
