Since updating to 2023.6.0 the sky connect stick is not working anymore (ZHA).
I already restarted several times, tried to put it into another usb port and so on.
At the moment, ZHA shows “Failed to set up”. When I reload the integration, the following things show up in the logs:
This is in the silabs multiprotocol (2.1.0) log:
Add-on: Silicon Labs Multiprotocol
Zigbee and OpenThread multiprotocol add-on
Add-on version: 2.1.0
You are running the latest version of this add-on.
System: Home Assistant OS 10.2 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2023.6.0
Home Assistant Supervisor: 2023.06.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service universal-silabs-flasher: starting
[10:56:56] INFO: Checking /dev/ttyUSB1 identifying SkyConnect v1.0 from Nabu Casa.
[10:56:56] INFO: Starting universal-silabs-flasher with /dev/ttyUSB1
2023-06-09 10:56:57 homeassistant universal_silabs_flasher.flash[170] INFO Extracted GBL metadata: NabuCasaMetadata(metadata_version=1, sdk_version='4.2.3', ezsp_version=None, ot_rcp_version=None, fw_type=<FirmwareImageType.RCP_UART_802154: 'rcp-uart-802154'>, baudrate=460800)
2023-06-09 10:56:57 homeassistant universal_silabs_flasher.flasher[170] INFO Probing ApplicationType.GECKO_BOOTLOADER at 115200 baud
2023-06-09 10:56:59 homeassistant universal_silabs_flasher.flasher[170] INFO Probing ApplicationType.CPC at 460800 baud
2023-06-09 10:56:59 homeassistant universal_silabs_flasher.flasher[170] INFO Detected ApplicationType.CPC, version '4.2.3' at 460800 baudrate (bootloader baudrate None)
2023-06-09 10:56:59 homeassistant universal_silabs_flasher.flash[170] INFO Firmware version '4.2.3' is flashed, not re-installing
s6-rc: info: service universal-silabs-flasher successfully started
s6-rc: info: service cpcd-config: starting
[10:57:00] INFO: Using known baudrate of 460800 for cpcd!
[10:57:01] INFO: Generating cpcd configuration.
s6-rc: info: service cpcd-config successfully started
s6-rc: info: service cpcd: starting
[10:57:02] INFO: Starting cpcd...
WARNING in function 'main' in file /usr/src/cpc-daemon/main.c at line #188 : Running CPCd as 'root' is not recommended. Proceed at your own risk.
s6-rc: info: service cpcd successfully started
s6-rc: info: service zigbeed: starting
s6-rc: info: service zigbeed successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[10:57:02] INFO: Starting zigbeed...
[10:57:02:026171] Info : [CPCd v4.2.2.0] [Library API v3] [RCP Protocol v3]
[10:57:02:026373] Info : Git commit: a4f53d8357b5432689773ec2eea117654f526705 / branch:
[10:57:02:026378] Info : Sources hash: 24f9802026e003036eec3dda618f8cf060114efc9551b2fdd5eb331416b64f31
[10:57:02:026386] WARNING : In function 'main' in file /usr/src/cpc-daemon/main.c at line #188 : Running CPCd as 'root' is not recommended. Proceed at your own risk.
[10:57:02:026438] Info : Reading cli arguments
[10:57:02:026448] Info : /usr/local/bin/cpcd
[10:57:02:034586] Info : Reading configuration
[10:57:02:034605] Info : file_path = /usr/local/etc/cpcd.conf
[10:57:02:034608] Info : instance_name = cpcd_0
[10:57:02:034610] Info : socket_folder = /dev/shm
[10:57:02:034613] Info : operation_mode = MODE_NORMAL
[10:57:02:034615] Info : use_encryption = false
[10:57:02:034618] Info : binding_key_file = /etc/binding-key.key
[10:57:02:034620] Info : binding_key_override = false
[10:57:02:034622] Info : binding_method =
[10:57:02:034625] Info : stdout_tracing = false
[10:57:02:034627] Info : file_tracing = false
[10:57:02:034628] Info : lttng_tracing = false
[10:57:02:034630] Info : enable_frame_trace = false
[10:57:02:034633] Info : traces_folder = /dev/shm/cpcd-traces
[10:57:02:034635] Info : bus = UART
[10:57:02:034637] Info : uart_baudrate = 460800
[10:57:02:034640] Info : uart_hardflow = true
[10:57:02:034642] Info : uart_file = /dev/ttyUSB1
[10:57:02:034644] Info : spi_file = /dev/spidev0.0
[10:57:02:034647] Info : spi_bitrate = 1000000
[10:57:02:034649] Info : spi_mode = SPI_MODE_0
[10:57:02:034651] Info : spi_bit_per_word = 8
[10:57:02:034653] Info : spi_cs_chip = gpiochip0
[10:57:02:034655] Info : spi_cs_pin = 8
[10:57:02:034658] Info : spi_irq_chip = gpiochip0
[10:57:02:034660] Info : spi_irq_pin = 22
[10:57:02:034662] Info : fu_reset_chip = gpiochip0
[10:57:02:034664] Info : fu_spi_reset_pin = 23
[10:57:02:034666] Info : fu_wake_chip = gpiochip0
[10:57:02:034668] Info : fu_spi_wake_pin = 24
[10:57:02:034670] Info : fu_recovery_enabled = false
[10:57:02:034672] Info : fu_connect_to_bootloader = false
[10:57:02:034674] Info : fu_enter_bootloader = false
[10:57:02:034676] Info : fu_file =
[10:57:02:034678] Info : restart_cpcd = false
[10:57:02:034680] Info : board_controller_ip_addr =
[10:57:02:034682] Info : application_version_validation = false
[10:57:02:034684] Info : print_secondary_versions_and_exit = false
[10:57:02:034686] Info : use_noop_keep_alive = false
[10:57:02:034689] Info : reset_sequence = true
[10:57:02:034691] Info : uart_validation_test_option =
[10:57:02:034693] Info : stats_interval = 0
[10:57:02:034695] Info : rlimit_nofile = 2000
[10:57:02:034697] Info : ENCRYPTION IS DISABLED
[10:57:02:034700] Info : Starting daemon in normal mode
[10:57:02:052652] Info : Connecting to Secondary...
[10:57:02:138166] Info : Connected to Secondary
[10:57:02:141618] Info : Secondary Protocol v3
[10:57:02:148652] Info : Secondary CPC v4.2.3
[10:57:02:152102] Info : Secondary bus speed is 460800
[10:57:02:155657] Info : Secondary APP vUNDEFINED
[10:57:02:155973] Info : Daemon startup was successful. Waiting for client connections
[10:57:03:792581] Info : New client connection using library v4.2.2.0
[10:57:03:799086] Info : Opened connection socket for ep#12
[10:57:03:799727] Info : Endpoint socket #12: Client connected. 1 connections
Listening on port 9999 for connection...
Accepting connection.
This is what my supervisor logs:
Logger: zigpy.application
Source: /usr/local/lib/python3.11/site-packages/zigpy/application.py:196
First occurred: 10:42:11 (9 occurrences)
Last logged: 10:57:44
Couldn't start application
File "/usr/local/lib/python3.11/site-packages/zigpy/application.py", line 193, in startup
await self.connect()
File "/usr/local/lib/python3.11/site-packages/bellows/zigbee/application.py", line 131, in connect
self._ezsp = await bellows.ezsp.EZSP.initialize(self.config)
File "/usr/local/lib/python3.11/site-packages/bellows/ezsp/__init__.py", line 150, in initialize
await ezsp._startup_reset()
File "/usr/local/lib/python3.11/site-packages/bellows/ezsp/__init__.py", line 141, in _startup_reset
await self.reset()
File "/usr/local/lib/python3.11/site-packages/bellows/ezsp/__init__.py", line 170, in reset
await self._gw.reset()
TimeoutError
Logger: homeassistant.components.zha.core.gateway
Source: components/zha/core/gateway.py:205
Integration: Zigbee Home Automation (documentation, issues)
First occurred: 10:42:15 (9 occurrences)
Couldn't start EZSP = Silicon Labs EmberZNet protocol: Elelabs, HUSBZB-1, Telegesis coordinator (attempt 1 of 3)
Couldn't start EZSP = Silicon Labs EmberZNet protocol: Elelabs, HUSBZB-1, Telegesis coordinator (attempt 2 of 3)
Couldn't start EZSP = Silicon Labs EmberZNet protocol: Elelabs, HUSBZB-1, Telegesis coordinator (attempt 3 of 3)
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 205, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.11/site-packages/zigpy/application.py", line 219, in new
await app.startup(auto_form=auto_form)
await self.reset()
TimeoutError
Logger: homeassistant.config_entries
First occurred: 10:42:55 (3 occurrences)
Error setting up entry SkyConnect Multi-PAN for zha
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 387, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 122, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 220, in async_initialize
raise exc
await self.reset()
TimeoutError
This is my System information btw:
## System Information
version | core-2023.6.0
installation_type | Home Assistant OS
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.11.3
os_name | Linux
os_version | 6.1.21-v8
arch | aarch64
timezone | Europe/Berlin
config_dir | /config
<details><summary>Home Assistant Community Store</summary>
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
GitHub API Calls Remaining | 4892
Installed Version | 1.32.1
Stage | running
Available Repositories | 1287
Downloaded Repositories | 15
</details>
<details><summary>Home Assistant Cloud</summary>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Home Assistant OS 10.2
update_channel | stable
supervisor_version | supervisor-2023.06.1
agent_version | 1.5.1
docker_version | 23.0.6
disk_total | 57.8 GB
disk_used | 27.7 GB
healthy | true
supported | true
board | rpi4-64
supervisor_api | ok
version_api | ok
installed_addons | Terminal & SSH (9.7.1), File editor (5.6.0), ESPHome (2023.5.5), FTP (4.7.0), Mosquitto broker (6.2.1), Studio Code Server (5.6.1), Grafana (8.3.0), ioBroker (0.8.0), InfluxDB (4.7.0), Warema Bridge (dev), Silicon Labs Multiprotocol (2.1.0), Baby Buddy (1.16.0)
</details>
<details><summary>Dashboards</summary>
dashboards | 13
resources | 2
views | 12
mode | storage
</details>
<details><summary>Miele</summary>
component_version | 0.1.13
reach_miele_cloud | ok
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | 8 June 2023 at 08:03
current_recorder_run | 9 June 2023 at 10:40
estimated_db_size | 1230.58 MiB
database_engine | sqlite
database_version | 3.41.2
</details>
