Problem with start Node-RED on HA
I have a problem with starting the Node-RED installation (19.0.2) on HAOS (15, same symptoms on 14.2). HAOS is freshly installed on the RPi 5. There are no other add-ons. The only Zigbee ZHA devices connected are via Sonoff USB Dongle Plus. The installation of HAOS is done on a MicroSD card. HA is available and works without problems, but after installing Node-RED with configuration:
theme: default
http_node:
username: ""
password: ""
http_static:
username: ""
password: ""
ssl: true
certfile: fullchain.pem
keyfile: privkey.pem
system_packages: []
npm_packages: []
init_commands: []
credential_secret: Haslo
the add-on does not start.
The screen remains blank, in the Node-RED logs there is only the entry “Loading log…”. There are no entries in the system logs.
I have already made many attempts to install and start. In one case, the add-on started and worked, but after a few hours the same problem appeared - a blank Node-RED screen.
A similar problem (blank screen) is with “Advanced SSH & Web Terminal”.
My additional problem is that I have never dealt with any version of Linux. It seemed to me that the ready-made HA OS would work correctly. And in fact, HAOS itself works. But why can’t I install the add-ons?
The hints on the Internet suggested changing HAOS from version 15 to 14.2, but the errors remained.
Regards
TAF
Have you tried setting SSL to ‘off’?
Also a full system reboot…
Ups. In this message I have placed an error in the code. I am doing all the tests with SSL disabled. And I did all the possible reboots
I have the same issue with a previously working setup. Getting following errors:
[09:35:12] INFO: Starting Node-RED...
> start
> node $NODE_OPTIONS node_modules/node-red/red.js --settings /etc/node-red/config.js
Error loading settings file: /etc/node-red/config.js
[09:35:14] INFO: Service Node-RED exited with code 1 (by signal 0)
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service nginx: stopping
[09:35:14] INFO: Service NGINX exited with code 256 (by signal 15)
s6-rc: info: service nginx successfully stopped
s6-rc: info: service init-nginx: stopping
s6-rc: info: service nodered: stopping
s6-rc: info: service nodered successfully stopped
s6-rc: info: service init-nodered: stopping
s6-rc: info: service init-nginx successfully stopped
s6-rc: info: service init-nodered successfully stopped
s6-rc: info: service init-customizations: stopping
s6-rc: info: service init-customizations successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
@taf you can also try to view the logs by going to settings in HA. System → logs → top right corner dropdown and select nodered.
@jedi_nabucasa Have you edited the setting.js file?
Have y’all tried starting NR with safe mode on?
