Hi there,
I am a bit newbie to HA but I love it already.
However, I came across some problems with HA not restarting properly after update. Can anyone help me how to fix it please?
root@DietPi:~# journalctl -u home-assistant
– Journal begins at Sat 2025-06-21 02:29:40 AEST, ends at Sun 2025-06-22 12:55:34 AEST. –
Jun 21 02:29:48 DietPi systemd[1]: Started Home Assistant (DietPi).
Jun 21 09:16:05 DietPi Home Assistant[1622]: 2025-06-21 09:16:05.544 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
Jun 21 09:16:18 DietPi Home Assistant[1622]: 2025-06-21 09:16:18.736 WARNING (MainThread) [aiohttp_fast_zlib] zlib_ng and isal are not available, falling back to zlib, performance will be degraded.
Jun 21 09:16:21 DietPi Home Assistant[1622]: 2025-06-21 09:16:21.194 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //mnt/dietpi_userdata/homeassistant/home-assistant_v2.db was shutdown cleanly
Jun 21 09:16:22 DietPi Home Assistant[1622]: 2025-06-21 09:16:22.180 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=67 from 2025-06-13 08:22:12.992742)
Jun 21 09:16:27 DietPi Home Assistant[1622]: 2025-06-21 09:16:27.103 ERROR (ImportExecutor_0) [homeassistant.components.camera.img_util] Error loading libturbojpeg; Camera snapshot performance will be sub-optimal
Jun 21 09:16:27 DietPi Home Assistant[1622]: Traceback (most recent call last):
Jun 21 09:16:27 DietPi Home Assistant[1622]: File “/home/homeassistant/.pyenv/versions/3.12.7/lib/python3.12/site-packages/homeassistant/components/camera/img_util.py”, line 100, in init
Jun 21 09:16:27 DietPi Home Assistant[1622]: TurboJPEGSingleton.__instance = TurboJPEG()
Jun 21 09:16:27 DietPi Home Assistant[1622]: ^^^^^^^^^^^
Jun 21 09:16:27 DietPi Home Assistant[1622]: File “/home/homeassistant/.pyenv/versions/3.12.7/lib/python3.12/site-packages/turbojpeg.py”, line 300, in init
Jun 21 09:16:27 DietPi Home Assistant[1622]: self.__find_turbojpeg() if lib_path is None else lib_path)
Jun 21 09:16:27 DietPi Home Assistant[1622]: ^^^^^^^^^^^^^^^^^^^^^^^
Jun 21 09:16:27 DietPi Home Assistant[1622]: File “/home/homeassistant/.pyenv/versions/3.12.7/lib/python3.12/site-packages/turbojpeg.py”, line 967, in __find_turbojpeg
Jun 21 09:16:27 DietPi Home Assistant[1622]: raise RuntimeError(
Jun 21 09:16:27 DietPi Home Assistant[1622]: RuntimeError: Unable to locate turbojpeg library automatically. You may specify the turbojpeg library path manually.
Jun 21 09:16:27 DietPi Home Assistant[1622]: e.g. jpeg = TurboJPEG(lib_path)
Jun 21 16:08:15 DietPi Home Assistant[1622]: 2025-06-21 16:08:15.737 ERROR (MainThread) [homeassistant.components.tplink.coordinator] Error fetching 192.168.8.101 data: Unable to connect to the device: 192.168.8.101:9999:
Jun 21 21:56:53 DietPi Home Assistant[1622]: 2025-06-21 21:56:53.957 ERROR (MainThread) [homeassistant.components.ipp.coordinator] Error fetching ipp data: Invalid response from API: Timeout occurred while connecting to IPP server.
After monthly update it is last few months never start again properly, I need to just reboot whole Odroid HC4.
I have HA installed natively not in docker.
Cheer
