Problem with temperature display in the dashboard
I’m currently trying out the dashboard for the first time and am having a display issue.
I’ve set the temperature unit to Celsius under Devices, but the dashboard displays the temperature in Fahrenheit. How can I adjust this?
Thanks!!
Torsten
Go to Settings > System > General and make sure your Unit System is set to Metric. Remember to click Update at the bottom and to refresh your browser, just in case.
Thank you very much, that was the solution.
Best regards, Torsten
