Hello everyone! I have a bit of a problem with a template sensor. I’m not great with jinja but i managed to get a sensor up and running for my trash pickup which is a bit special.
We have pickup every other week during most of the year, but during the week numbers 25-34 the trash is picked up every week. The sensor changes status when i select that the trash is taken out via the input boolean. Its been working great, until week 25 this year, now no matter if i select trash taken out the sensor still says “Put out the trash”.
Really thought i nailed the template when i created it. I have spent several hours trying to figure out how to write it correctly, would gladly appreciate any help!
sensors:
sophamtning:
friendly_name: Trash Pickup
value_template: >
{% set wk = strptime(states('sensor.date'), '%Y-%m-%d').strftime('%V')|int %}
{% if is_state('input_select.trash_taken_out', 'No') and (now().isocalendar()[1]/2)|round(0)==(now().isocalendar()[1]/2) or wk >= 25 and wk <= 34 %}
Put out the trash!
{% else %}
No
{% endif %}
- platform: time_date
display_options:
- time
- date
- date_time
- time_date
input_select:
trash_taken_out:
name: Are the trash taken out?
options:
- No
- Yes
sensors:
sophamtning:
entity_id:
- sensor.date
- input_select.trash_taken_
value_template: >
{% set wk = now().isocalendar()[1] %}
{{ 'Put out the trash!'
and (wk % 2 == 0 or (25 <= wk <= 34))
else 'No' }}
The template works like this:
It sets wk to week of the year.
It reports Put out the trash! if the input_select is No AND wk is an even number OR if it’s between 25 and 34 (inclusive).
Otherwise, it reports No.
EDIT
Correction. Added entities to monitor as per Phil’s suggestion (see below). Listeners are assigned to entities whereas now() is a function, not an entity.
Do you have a precedence issue in your if statement?
{% if is_state('input_select.trash_taken_out', 'No') and ((now().isocalendar()[1]/2)|round(0)==(now().isocalendar()[1]/2) or (wk >= 25 and wk <= 34)) %}
OMG sorry! Did not see your post when i viewed it on my phone before only saw pnbruckners post and andrewdolphin. I’m now using your example instead. So much easier to read, and i now understand what i did wrong! Thanks a million!
