Problem with the the time_throttle filter with repeated values
I’m trying to use the filter integration on some rapidly reporting sensors to reduce the volume of data sent to a database. I still want the sensor to report rapidly so I can have the dashboard update close to real time.
An example:
  - platform: filter
    name: "filtered sensor.coffee_machine_energy_power"
    entity_id: sensor.coffee_machine_energy_power
    filters:
      - filter: time_simple_moving_average
        window_size: "00:01"
      - filter: time_throttle
The problem occurs when the coffee machine is turned off - after that point, the unfiltered sensor stops updating (because it isn’t changing, as it is always 0). However, from what I can see once that happens, the time_throttle filter never gets triggered, so it ‘sticks’ on whatever the last value it emitted happened to be - and never goes to 0. Am I doing something wrong here? How do I work around it?
No. Filters only update on state changes.
Hmm. That pretty much renders the throttle filters useless for sensors which have long periods on one value, which is a bit unfortunate.
The throttle filter reduces the number of changes. It cannot increase them.
https://www.home-assistant.io/integrations/filter/#throttle
This filter is relevant when you have a sensor which produces states at a very high-rate, which you might want to throttle down for storing or visualization purposes.
Yeah, the problem here is I have a high rate of change while the device is active, which I would like to filter, and then it goes to 0 and stays that way for a long period of time - and if that 0 gets dropped, it stays at the last value that got past the filter, which is kind of bad for doing statistics on.
In this particular case I suppose I want some way of exempting 0 values from being throttled, but that isn’t really a general solution.
Or alternatively have another thing which checks periodically if the unfiltered value is 0, and then updates the filtered value if it is.
This is the way I throttle my bed occupancy sensor:
    filters:
      - sliding_window_moving_average:
          window_size: 10
          send_every: 1
      - or:
          - throttle: 180s
          - delta: 0.02
It sends the moving average every 3 minutes unless there has been a significant change (delta is set just above the average noise floor) in which case it sends it immediately.
Maybe you could use something like that?
This isn’t Home Assistant filter. Is it right?
By(t)e
ESPHome only.
Which looking back now I can see was rather confusing.
A simple way to time decimate, is to trigger the template on a time interval (like once a minute, once every 5 minutes, etc,)
Yes that is what this does (Home Assistant).
  - platform: filter
    entity_id: sensor.foobar
    filters:
        window_size: "00:60"
