Problem with Tuya in 2024.2
Tuya integration shows invalid hex color: black instead of QR code. :thinking:
I have the same issue. “Invalid hex color: rgba(25, 25, 25, 0.9)”
You have to change your theme back to default. Then it will start to work.
I’m also experiencing this, however my theme has always been on default, so that didn’t seem to fix the issue for me.
I have the same issue too :frowning:
I’ve solved the problem by restoring to 2024.1.6 from backup
Same problem here.
Solution:
Changed theme from google dark theme to Home Assistant dark theme and the QR-Code appeared.
But what’s the issue then with custom themes?
That’s it. Thank you!
I can confirm setting the theme back to default resolves this for me
Thank you. It works, but I hope the great devs behins this project fix this issue :grinning:
This has nothing to do with the developers of this project. It is the custom theme that did not take this scenario into account in their theme…
Thank You. It works for me to.
My savior…THANKS
It’s useful
