I have problem with Xiaomi Gateway lumi.gateway.v3 but Mi Home App work fine. I install HASS.io image on Rasberry Pi3 B+. I use only Windows and Mac and this is the first time for me to step up for other OS.
2018-11-07 23:13:42 WARNING (MainThread) [homeassistant.setup] Setup of xiaomi_aqara is taking over 10 seconds.
2018-11-07 23:14:22 ERROR (SyncWorker_6) [homeassistant.components.xiaomi_aqara] No gateway discovered
2018-11-07 23:14:22 ERROR (MainThread) [homeassistant.setup] Setup failed for xiaomi_aqara: Component failed to initialize.
I try to search troubleshoot and follow the instruction but nothing changed. Here are my config and setting.
I use iPhone to add gateway in Mi Home App.
xiaomi_aqara:
discovery_retry: 10
gateways:
- mac:
key: xxxxxxxxxxxxxx
- Make sure you have [enabled LAN access] -->Done
- Turn off the firewall on the system where Home Assistant is running. -->Done
- Ensure your router supports multicast as this is a requirement of the Xiaomi Gateway. --> My router is D-Link DIR859 and I already enable multicast steam both IPv4&IPv6 (not sure is it the same thing)
- Try to leave the MAC address
mac:
blank.–>Done - Try to set
discovery_retry: 10
. -->Done - Try to disable and then enable LAN access. -->Done
- Hard reset the gateway: Press the button of the gateway 30 seconds and start again from scratch. -->Done
- If you are using Home Assistant in Docker, make sure to use
--net=host
. --> don’t know what does it mean and how to do it.
I am not sure what I am missing to make HASS can find Xiaomi Gateway
