Hello @Rludo974 ,
Welcome to the forum!
If you want help, you may want to edit your post and translate everything into English. (You could use DeepL, Google Translate or ChatGPT if you don’t speak English).
There is also a French forum: Home Assistant Communauté Francophone - Communauté francophone sur Home Assistant avec des tutoriels, des articles, de l’aide, du partage.
