buongiorno a tutti sono nuovo in HA e spero di scrivere nel posto corretto.
ho appena installato un’antenna smlight SLZB-06M ma continua a darmi questi errore negli script. Ho provato di tutto seguendo vari tutorial ma niente.
Aiuto…GRAZIE
‘’‘[18:34:11] INFO: Preparing to start…
[18:34:11] INFO: Socat not enabled
[18:34:12] INFO: Starting Zigbee2MQTT…
Starting Zigbee2MQTT without watchdog.
[2025-03-02 18:34:14] info: z2m: Logging to console, file (filename: log.log)
[2025-03-02 18:34:14] info: z2m: Starting Zigbee2MQTT version 2.1.3 (commit #unknown)
[2025-03-02 18:34:14] info: z2m: Starting zigbee-herdsman (3.2.7)
[2025-03-02 18:34:15] error: z2m: Error while starting zigbee-herdsman
[2025-03-02 18:34:15] error: z2m: Failed to start zigbee-herdsman
[2025-03-02 18:34:15] error: z2m: Check Zigbee2MQTT fails to start/crashes runtime | Zigbee2MQTT for possible solutions
[2025-03-02 18:34:15] error: z2m: Exiting…
[2025-03-02 18:34:15] error: z2m: Error: USB adapter discovery error (No valid USB adapter found). Specify valid ‘adapter’ and ‘port’ in your configuration.
at discoverAdapter (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/adapterDiscovery.ts:523:15)
at processTicksAndRejections (node:internal/process/task_queues:105:5)
at Function.create (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/adapter.ts:68:33)
at Controller.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/controller.ts:132:24)
at Zigbee.start (/app/lib/zigbee.ts:69:27)
at Controller.start (/app/lib/controller.ts:142:13)
at start (/app/index.js:161:5)
[2025-03-02 18:34:15] error: z2m: If this happens after updating to Zigbee2MQTT 2.0.0, see Z2M 2.0.0: `USB adapter discovery error (No valid USB adapter found)` · Koenkk/zigbee2mqtt · Discussion #24364 · GitHub ‘’’
