Problems getting code to work
I have had this code working for sometime recently it stopped working, I’ve looked at the Templates HA page and noticed its using a legacy format. I have tried to correct it but everytime I just get errors! Can anyone help?
template:
  - sensors:
      front_sump_on_24:
        friendly_name: "Front sump on over 24H"
        value_template: '{{ states("sensor.front_sump_pump_energy_current_2") | float > 1 }}'
Many thanks
James
there should be no reason that the legacy template code would have stopped working if it had worked before. I have many template sensors running on the legacy format and I have no issues.
the new template format uses different key options for the sensors.
template:
  - sensors:
      state: '{{ states("sensor.front_sump_pump_energy_current_2") | float > 1 }}'
note that the entity_id of the sensor will change because the new format gets the entity_id from the name. the old format got the entity_id from the entity id you created.
Thank you for your response the issue I have is that I get ‘Entity not available’ on the dashboard and this in the log file.
Logger: homeassistant.helpers.template
Source: helpers/template.py:540
First occurred: 14 February 2023 at 14:51:48 (2318 occurrences)
Last logged: 10:09:02
Template variable error: 'sensor' is undefined when rendering '{{ states(sensor.front_sump_pump_energy_current_2) | float > 1 }}'
Template variable error: 'sensor' is undefined when rendering '{{ states(sensor.sump_pump_energy_current) | float > 1 }}'
That’s because you aren’t using the correct syntax.
you need to quote the inside of the parenthesis. And they need to be different than the quotation marks outside the brackets.
see the difference between the error message and my example.
