Problems integrating Philips Hue TAP & DIMMER
I’m in the process of migrating my Philips Hue Devices from Philips Hue Bridge to Zigbee2MQTT using the SMLIGHT SMZB-06 and all the lights are working just fine.
I’ve also ADDED the Dimmers and Taps in the different rooms and when looking at the log in Zigbee2MQTT, it does register when I push the buttons.
When trying to setup what happens when the different buttons are pressed, I don’t see the devices neither when setting up automations manually or when using two different Philips Hue Dimmer blueprints from the blueprint exchange.
When trying to pick the given Dimmer or Tap device, the drop down menu just says “No matching devices found”.
Can anyone explain to me how I should be able to get this working ?
