Problems loading plugins
Attempting to use the plugin slider-entity-row, but having issues getting it to work.
https://github.com/thomasloven/lovelace-slider-entity-row
Errors:
2019-08-21 18:10:07 ERROR (MainThread) [frontend.js.latest.201908050] http://192.168.0.141:8123/local/plugins/slider-entity-row.js:7:1 Uncaught SyntaxError: Unexpected token <
Everything online points to this being symptom of not properly downloading the file in Raw format from Github, but that’s not the case for me.
Read and followed several examples, directions and more online, but cannot figure out why I’m running into the error.
I’ve tried downloading the raw javascript file, copy/pasting raw js content into a new file, tried playing with file placement in /local/ as well as a /local/plugins/ folder I created ("/local/" being /<hass config DIR>/www).
Tried recycling Home Assistant between each attempt to troubleshoot.
I’m referencing and calling it in lovelace YAML config according to instructions on the source git hub page and custom card documentation. Tried following other plugin examples online as well.
Running Docker Home Assistant instance, v0.97.2
You need to show the Lovelace resources section and an example of where you are using the card. We aren’t mind readers and can’t help if you provide no useful information. I also use that plugin so it definitely works…
Thank you Dave.
Here’s what I’m using to load the plugin/module and the card config to call it:
Lovelace YAML reference to pull it in:
title: Home
resources:
  - url: /local/slider-entity-row.js
    type: module
Card config (after adding an Entities card and changing with editor):
type: entities
entities:
  - type: custom:slider-entity-row
    entity: light.zooz_zen22_dimmer_v2_level
Did you make sure you installed the RAW code and that the file doesn’t just include HTML?
Yes.
root@d5fd106404d6:/config/www# cat slider-entity-row.js
!function(t){var e={};function s(i){if(e[i])return e[i].exports;var r=e[i]={i:i,l:!1,exports:{}};return t[i].call(r.exports,r,r.exports,s),r.l=!0,r.exports}s.m=t,s.c=e,s.d=function(t,e,i){s.o(t,e)||Object.defineProperty(t,e,{enumerable:!0,get:i})},s.r=function(t){"undefined"!=typeof Symbol&&Symbol.toStringTag&&Object.defineProperty(t,Symbol.toStringTag,{value:"Module"}),Object.defineProperty(t,"__esModule",{value:!0})},s.t=function(t,e){if(1&e&&(t=s(t)),8&e)return t;if(4&e&&"object"==typeof t&&t&&t.__esModule)return t;var i=Object.create(null);if(s.r(i),Object.defineProperty(i,"default",{enumerable:!0,value:t}),2&e&&"string"!=typeof t)for(var r in t)s.d(i,r,function(e){return t[e]}.bind(null,r));return i},s.n=function(t){var e=t&&t.__esModule?function(){return t.default}:function(){return t};return s.d(e,"a",e),e},s.o=function(t,e){return Object.prototype.hasOwnProperty.call(t,e)},s.p="",s(s.s=0)}([function(t,e,s){"use strict";s.r(e);const i=Object.getPrototypeOf(customElements.get("hui-view")),r=i.prototype.html,a=i.prototype.css;class n{constructor(t){this._config=t}set hass(t){this._hass=t,this.stateObj=this._config.entity in t.states?t.states[this._config.entity]:null}get value(){return this._value?Math.round(this._value/this.step)*this.step:0}set value(t){t!==this.value&&(this._value=t)}get string(){return`${this.value}`}get hidden(){return!1}get hasSlider(){return!0}get hasToggle(){return!0}get isOff(){return 0===this.value}get min(){return void 0!==this._config.min?this._config.min:void 0!==this._min?this._min:0}get max(){return void 0!==this._config.max?this._config.max:void 0!==this._max?this._max:100}get step(){return void 0!==this._config.step?this._config.step:void 0!==this._step?this._step:5}}const u={light:class extends n{get attribute(){return this._config.attribute||"brightness"}get _value(){if("on"!==this.stateObj.state)return 0;switch(this.attribute){case"color_temp":return Math.ceil(this.stateObj.attributes.color_temp);case"brightness":return Math.ceil(100*this.stateObj.attributes.brightness/255);case"red":return this.stateObj.attributes.rgb_color?Math.ceil(this.stateObj.attributes.rgb_color[0]):0;case"green":return this.stateObj.attributes.rgb_color?Math.ceil(this.stateObj.attributes.rgb_color[1]):0;case"blue":return this.stateObj.attributes.rgb_color?Math.ceil(this.stateObj.attributes.rgb_color[2]):0;case"hue":return this.stateObj.attributes.hs_color?Math.ceil(this.stateObj.attributes.hs_color[0]):0;case"saturation":return this.stateObj.attributes.hs_color?Math.ceil(this.stateObj.attributes.hs_color[1]):0;default:return 0}}get _min(){switch(this.attribute){case"color_temp":return this.stateObj.attributes.min_mireds;default:return 0}}get _max(){switch(this.attribute){case"color_temp":return this.stateObj.attributes.max_mireds;case"red":case"green":case"blue":return 255;case"hue":return 360;default:return 100}}set _value(t){let e,s=this.attribute,i=!0;switch(s){case"brightness":(t=Math.ceil(t/100*255))||(i=!1);break;case"red":case"green":case"blue":e=this.stateObj.attributes.rgb_color||[0,0,0],"red"===s&&(e[0]=t),"green"===s&&(e[1]=t),"blue"===s&&(e[2]=t),t=e,s="rgb_color";break;case"hue":case"saturation":e=this.stateObj.attributes.hs_color||[0,0],"hue"===s&&(e[0]=t),"saturation"===s&&(e[1]=t),t=e,s="hs_color"}i?this._hass.callService("light","turn_on",{entity_id:this.stateObj.entity_id,[s]:t}):this._hass.callService("light","turn_off",{entity_id:this.stateObj.entity_id})}get string(){if("off"===this.stateObj.state)return this._hass.localize("state.default.off");switch(this.attribute){case"color_temp":return`${this.value} K`;case"brightness":case"saturation":return`${this.value} %`;case"hue":return`${this.value} °`;default:return this.value}}get hasSlider(){switch(this.attribute){case"brightness":if("brightness"in this.stateObj.attributes)return!0;if("supported_features"in this.stateObj.attributes&&1&this.stateObj.attributes.supported_features)return!0;case"color_temp":if("color_temp"in this.stateObj.attributes)return!0;if("supported_features"in this.stateObj.attributes&&2&this.stateObj.attributes.supported_features)return!0;case"red":case"green":case"blue":if("rgb_color"in this.stateObj.attributes)return!0;if("supported_features"in this.stateObj.attributes&&16&this.stateObj.attributes.supported_features)return!0;case"hue":case"saturation":if("hs_color"in this.stateObj.attributes)return!0;if("supported_features"in this.stateObj.attributes&&16&this.stateObj.attributes.supported_features)return!0;default:return!1}}},media_player:class extends n{get _value(){return"on"===this.stateObj.is_volume_muted?0:Math.ceil(100*this.stateObj.attributes.volume_level)}set _value(t){t/=100,this._hass.callService("media_player","volume_set",{entity_id:this.stateObj.entity_id,volume_level:t})}get isOff(){return"off"===this.stateObj.state}get string(){return this.stateObj.attributes.is_volume_muted?"-":this.stateObj.attributes.volume_level?`${this.value} %`:this._hass.localize("state.media_player.off")}get hasToggle(){return!1}},climate:class extends n{get _value(){return this.stateObj.attributes.temperature}set _value(t){this._hass.callService("climate","set_temperature",{entity_id:this.stateObj.entity_id,temperature:t})}get string(){return"off"===this.stateObj.attributes.hvac_mode?this._hass.localize("state.climate.off"):`${this.value} ${this._hass.config.unit_system.temperature}`}get isOff(){return"off"===this.stateObj.attributes.hvac_mode}get _min(){return this.stateObj.attributes.min_temp}get _max(){return this.stateObj.attributes.max_temp}get _step(){return 1}},cover:class extends n{get attribute(){return this._config.attribute||"position"}get _value(){switch(this.attribute){case"position":return"open"===this.stateObj.state?this.stateObj.attributes.current_position:0;case"tilt":return this.stateObj.attributes.current_tilt_position;default:return 0}}set _value(t){switch(this.attribute){case"position":this._hass.callService("cover","set_cover_position",{entity_id:this.stateObj.entity_id,position:t});break;case"tilt":this._hass.callService("cover","set_cover_tilt_position",{entity_id:this.stateObj.entity_id,tilt_position:t})}}get string(){if(!this.hasSlider)return"";switch(this.attribute){case"position":return"closed"===this.stateObj.state?this._hass.localize("state.cover.closed"):`${this.value} %`;case"tilt":return this.value}}get hasToggle(){return!1}get hasSlider(){switch(this.attribute){case"position":if("current_position"in this.stateObj.attributes)return!0;if("supported_features"in this.stateObj.attributes&&4&this.stateObj.attributes.supported_features)return!0;case"tilt":if("current_tilt_position"in this.stateObj.attributes)return!0;if("supported_features"in this.stateObj.attributes&&128&this.stateObj.attributes.supported_features)return!0;default:return!1}}get _step(){return 10}},fan:class extends n{get _value(){return"off"!==this.stateObj.state?this.stateObj.attributes.speed_list.indexOf(this.stateObj.attributes.speed):0}set _value(t){t in this.stateObj.attributes.speed_list?this._hass.callService("fan","turn_on",{entity_id:this.stateObj.entity_id,speed:this.stateObj.attributes.speed_list[t]}):this._hass.callService("fan","turn_off",{entity_id:this.stateObj.entity_id})}get string(){return"off"===this.stateObj.state?this._hass.localize("state.default.off"):this.stateObj.attributes.speed}get hasSlider(){return"speed"in this.stateObj.attributes}get _max(){return this.stateObj.attributes.speed_list.length-1}get _step(){return 1}},input_number:class extends n{get _value(){return this.stateObj.state}set _value(t){this._hass.callService("input_number","set_value",{entity_id:this.stateObj.entity_id,value:t})}get string(){return`${parseFloat(this.stateObj.state)} ${this.stateObj.attributes.unit_of_measurement||""}`.trim()}get isOff(){return!1}get hasToggle(){return!1}get hasSlider(){return"slider"===this.stateObj.attributes.mode}get _min(){return this.stateObj.attributes.min}get _max(){return this.stateObj.attributes.max}get _step(){return this.stateObj.attributes.step}},input_select:class extends n{get _value(){return this.stateObj.attributes.options.indexOf(this.stateObj.state)}set _value(t){t in this.stateObj.attributes.options&&this._hass.callService("input_select","select_option",{entity_id:this.stateObj.entity_id,option:this.stateObj.attributes.options[t]})}get string(){return this.stateObj.state}get isOff(){return!1}get hasToggle(){return!1}get hasSlider(){return this.stateObj.attributes.options&&this.stateObj.attributes.options.length>0}get _max(){return this.stateObj.attributes.options.length-1}get _step(){return 1}}};customElements.define("slider-entity-row",class extends i{static get properties(){return{hass:{}}}setConfig(t){this._config=t;const e=t.entity.split(".")[0],s=u[e];if(!s)throw new Error(`Unsupported entity type: ${e}`);this.ctrl=new s(t)}render(){const t=this.ctrl;t.hass=this.hass;const e=r`
      <ha-slider
        .min=${t.min}
        .max=${t.max}
        .step=${t.step}
        .value=${t.value}
        pin
        @change=${e=>t.value=this.shadowRoot.querySelector("ha-slider").value}
        class=${this._config.full_row?"full":""}
      ></ha-slider>
    `,s=r`
      <ha-entity-toggle
        .stateObj=${this.hass.states[this._config.entity]}
        .hass=${this.hass}
      ></ha-entity-toggle>
    `,i=r`
    <div class="wrapper" @click=${t=>t.stopPropagation()}>
      ${"unavailable"===t.stateObj.state?r`
          <span class="state">
          unavailable
          </span>
        `:r`
          ${this._config.hide_when_off&&t.isOff||!t.hasSlider?"":e}
          ${this._config.hide_state||this._config.toggle?"":r`
                ${t.string}
              </span>
          ${this._config.toggle&&t.hasToggle?s:""}
    </div>
    `;return this._config.full_row?i:r`
    <hui-generic-entity-row
      .hass=${this.hass}
      .config=${this._config}
    > ${i} </hui-generic-entity-row>
    `}static get styles(){return a`
      .wrapper {
        display: flex;
        align-items: center;
        height: 40px;
      .state {
        min-width: 45px;
        text-align: end;
      ha-entity-toggle {
        margin-left: 8px;
      ha-slider.full {
        width: 100%;
Did you just create www? Did you restart HA after creating it?
I’d already created www to get some jpg’s in for pitcure-elements card in the past, and yes, I’ve restarted HA several times since adding www and the plugin.
Have you just updated it? The way you are using it you need a ?/v=0.1 or the like on the end… Or try F12 in chrome and then right click on the refresh button and select Empty Cache and Hard Reload.
I did try that at first, went ahead and added back in to try again and now it works… ugh…
Maybe I ditched the ?/v=0.1 while troubleshooting before noticing I hadn’t grabbed raw before, not sure at this point, but I’m assuming that was the fix. Thank you!
I always use Ctrl+F5 for clear cache + refresh, but I’ll keep your method you described in mind for future. Didn’t need either in this case.
Another thing I notice is after restarting HA the Lovelace resources type and url get changed automatically to the following (which seems to still work):
resources:
  - type: module
    url: /local/slider-entity-row.js?/v=0.1
-vs- what I originally put in:
resources:
  - url: /local/slider-entity-row.js?/v=0.1
    type: module
The version at the end causes the browser to reload the file when you increment the number eliminating caching issues.
The empty cache & hard reload is a different option and it also fixes any caching issues.
Lastly… yes the GUI editor reorders things alphabetically. It’s not important.
