I’m running Home Assistant in a Proxmox VM and ESPHome the ESPHome add-on was installed. When a recent ‘update’ prompt came along I clicked it but got an error.
I tried restarting the HA VM but the problem persisted.
I googled to see if anyone had a similar problem and it seemed some people had success uninstalling and re-installing the add-on.
I removed the add on, but I get the same error when trying to install the add-on again.
The error is:
23-12-23 17:22:15 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/esphome/esphome-hassio:2023.12.3: 500 Server Error for http+docker://localhost/v1.43/images/ghcr.io/esphome/esphome-hassio:2023.12.3/json: Internal Server Error ("layer does not exist")
I think the last suggestion I found was to re-install home assistant, which I’d rather avoid if possible. Does anyone have an idea of a way to fix this ?
