I am trying to get the official Feedreader-integration working, but it does not seem to do anything.
I added the following to my configuration.yaml:
feedreader:
urls:
- https://www.home-assistant.io/atom.xml
scan_interval:
minutes: 30
After that, I restart HA (just for good measure, I restarted it twice), but the integration does not show up in my settings-screen (Devices & Services). I would have expected it to become visible in the integrations-section there, since it is an integration.
Am I doing something wrong, or do I need to look elsewhere in HA to it? I know there won’t automatically be a card on the dashboard, but I would expect some kind of confirmation that Feedreader is active.
Nothing
(Nothing)
January 28, 2024, 3:53pm
2
type: markdown
content: >+
** {{ states('input_text.newsitem_title')}}
**{{ states('input_text.newsitem_description')}}**
{{ as_datetime(states('input_datetime.newsitem_date')).strftime('%B %d, %Y
%H:%M:%S') }} - [Open Link]( {{ states('input_text.newsitem_link') }})
title: Dernière actualité
alias: News RSS
description: News
- platform: event
event_type: feedreader
event_data:
feed_url: https://www.cnews.fr/googlenews.xml
condition: []
- service: input_text.set_value
value: "{{ trigger.event.data.title }}"
entity_id: input_text.newsitem_title
enabled: true
value: "{{ trigger.event.data.description }}"
entity_id: input_text.newsitem_description
enabled: true
value: "{{ trigger.event.data.link }}"
entity_id: input_text.newsitem_link
enabled: true
- service: input_datetime.set_datetime
entity_id: input_datetime.newsitem_date
datetime: "{{ trigger.event.datetime }}"
- service: notify.mobile_app_phone_XXXXXXXXXXXXXXXXXX
metadata: {}
message: |
** {{ states('input_text.newsitem_title')}}.
**{{ states('input_text.newsitem_description')}}**.
{{ as_datetime(states('input_datetime.newsitem_date')).strftime('%B %d, %Y %H:%M:%S') }}
You are a legend! It works now, thank you very much!
FilipeOS
(Filipe Os)
August 23, 2024, 9:04pm
4
why you add that to config file if you can add it in UI? I added in UI and never gets fired…
That has recently been changed. I believe in version 2024.7
Mattie
(Mattias)
September 11, 2024, 7:15pm
6
is there a way to change the scan interval with the UI integration??
I want to sort the rss posts from different feeds by date and it wont work if it scans every hour, it gets like 5 posts from some sites at the exact same time
evroekel
(EvR)
November 27, 2024, 7:02pm
7
Same issue here. Did you solve it in the meantime?
ID_Ant
December 15, 2024, 6:03pm
8
Trying to get this to work with BBC News RSS feed if anyone has had any luck and would like to share?
FilipeOS
(Filipe Os)
January 24, 2025, 2:14pm
9
