I have a script that logs chores to grocy trough a shell_command. The script is turned on by a tap_action in lovelace. Since I only want to list chores that are due today, I am using the addons auto-entities and template-entity-row. Everything works fine, except for the shell_command.
This is my config:
tap_action in lovelace:
tap_action:
action: call-service
service: script.grocy_track_chore
service_data:
id: '{{ state_attr("this.entity_id", ''chore'')[''id''] }}'
script.grocy_track_chore:
grocy_track_chore:
sequence:
- service: script.notify
data_template:
message: "{{ id }}"
- service: shell_command.grocy_track_chore
data_template:
grocy_key: !secret grocy
chore_id: "{{ id }}"
tracked_time: "{{ now() }}"
- delay: 1
- service: homeassistant.update_entity
entity_id: group.grocy
And shell_command.grocy_track_chore:
grocy_track_chore: "curl -X POST http://192.168.0.129:9192/api/chores/{{chore_id}}/execute -H 'Accept: application/json' -H 'Content-Type: application/json' -H 'GROCY-API-KEY: {{grocy_key}}' -H 'cache-control: no-cache' -d '{ \"tracked_time\": {{tracked_time}}, \"done_by\": 0 }'"
If I try to run the script from services in developer tools, and add an ID, everything is working fine and the shell_command gets executed. But if I tap the sensor in lovelace I get this error:’
Error running command: `curl -X POST http://192.168.0.129:9192/api/chores/{{chore_id}}/execute -H 'Accept: application/json' -H 'Content-Type: application/json' -H 'GROCY-API-KEY: {{grocy_key}}' -H 'cache-control: no-cache' -d '{ "tracked_time": {{tracked_time}}, "done_by": 0 }'`, return code: 3
It looks like the template in shell_command is not getting sent through when I am running it from lovelace. I cannot understand why?
I also added a notify in my script to help debugging, and the message I receive looks the same, and contains a number, both when I type it in manually in service-calls and when I am running the script from lovelace.
The shell_command also works if I remove the template and replace it with a number, like this:
tap_action:
service_data:
So I am pretty sure that I am doing something wrong with my template-code in tap_action, but I cannot figure out what, since everything looks good, and the same, on the notify-message I am receiving.
