I have a Mitsubishi heat pump (air/air) that I have integrated with MELCloud. It has started behaving a little funny by just turning it off ever now and then. I suspect that this might occur when I ask google assistant to stop music etc not sure though. I have somehow intended to set an automation that when the heat pump’s “HVAC mode” changes, I will receive a notification to my mobile. I choose the trigger “Heat pump HVAC mode has changed”, once I select this, I get the error message “Message malformed: extra keys not allowed @ data [‘for’]”. I have no idea what this means? If I change the trigger to “Heat pump measured temperature has changed” it works without problems. Anyone have an idea what the problem might be?
I guess that it has something to do with “condition: [ ]”? As I mentioned eralier, I want HA to send me a notification when the heating pump is turen off.
OK, thanks for the explanation. But it must be something that is connected to the trigger “hvac_mode_changed” due to the fact that it works fine if I change the trigger to something else but with the same unit.
Reviving an old post but I’m having the exact same error and problem when using the visual editor and trying to set an automation for a Mysa smart thermostat for a in wall electric heater. Any resolution to your issue?
